Question about Dell 962 Photo All-In-One InkJet Printer
Printer will not turn on
Had a paper jam, I fixed that then the printer started making a high pitched sound and gave me an error code of 2200. So I unplugged it because it would not power off. Now when I plug it in I get the same beepping sound. It stops after a couple of minutes but it will not power on. Dell says my warrenty is up so the only thing they can do is sell me a new one. Thank you
  • Theresa Holloway Aug 15, 2006
    I found out how to fix this problem. You must unscrew the glass part of the scanner. Plug in the power cord and when it comes on pull on the scanner part. This will unjam it and it starts working again.
    Sergeant:
  • 390 Answers
Well done tee1, sometimes it just takes a bit of self confidence. Sometime a paper jam can be bad enough to unsettle important working parts, enen by a few tiny mm's and this will be enough to throw a spanner in the works. Make sure you write down your problem solver in a fix it book. This is what i do so i never forget haow to fix a problem. Keep it at you office area or near printer.
Posted on Feb 14, 2008
I M facing paper jam error problem after replacing sleev of fuser. Make Canon iR2318L.
is it showing some error code.open the fuser unit and then check the pressure roller bushes.sometimes they move from there place causing paper jams.do check whether u have applied right amount of grease to the fixing film and do check whether the white sensor of the film is in right position.u have to just fit all the parts rightly .it has something to do with these said things
Aug 15, 2011 | Canon imageRUNNER 2200
Paper from tray 2 starts to load then you here a high pitch squeak then paper jams and gives error code 241.09. Pull paper out of bottom tray reinsert paper then is fine till it jams again. Any thoughts.
If its some thing that just started, then you may want tocheck if you are using a new paper manufacturer. Sometimes frequent jams arecaused by thin paper.
Mar 02, 2011 | Dell 5210n Laser Printer
Canon mp830 displays error message. Paper output
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My printer is making a high pitched sound and it sounds like its trying to grip the paper but nothing seems to happen?
Hello there
Feb 27, 2010 | Lexmark X75 All-In-One InkJet Printer
THe screen is showing ERROR...Carriage jam open
Hello there
Nov 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
Canon MP810 Error Code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Mar 22, 2009 | Canon PIXMA MP810 All-In-One InkJet...
I have a canon mp830. I had the 6A00 error code.
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Feb 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 01, 2008 | Canon Pixma MP800 All-In-One InkJet...
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Dell 962 Photo All-In-One InkJet Printer Logo
97 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
