Question about Kenmore Dryers
Model 110.86984100 dryer will not start when start button is pressed
5 Suggested Answers
  • 958 Answers
SOURCE: Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
  • 74 Answers
SOURCE: kenmore dryer model # 110. 79902890 press the
you have a problem with a component called a capacitor.the capacitor stores an electric charge.this charge gives the motor the "kick" needs to start.if you have a faulty one the motor will hum because it cant turn.it should only be replaced by a competent appliance technician.
Posted on Oct 07, 2009
Jahn27
  • 1554 Answers
SOURCE: kenmore gas dryer model 110
The motor is overheating and trips the thermal overload protector which doesn't reset until the motor has cooled down. That is the reason the dryer restarts only after about 20 minutes when the motor has cooled down. Turn the drum manually to check if turns freely. The motor gets overloaded and overheats if the drum is restricted. Also make sure the dryer's inside, particularly the base where the motor is located, and vents are clear to allow proper air circulation and prevent the motor from overheating.
The only viable solution is replacing the motor if the drum turns freely and the cabinet and vents are clear but the dryer still shuts off. The motor has winding problems and it cannot be repaired and only replacing it will solve the problem.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Feb 12, 2011
Jahn27
  • 1554 Answers
SOURCE: When I press the start
There's no reset button and the problem is likely a blown thermal fuse. This thermal fuse is wired in series with the motor and if it's blown open, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located behind the bottom front panel.
Remove the two screws from the bottom flange of the panel then pull the panel down and off the cabinet.
Make sure the lint filter is clean the vent system is not restricted then check the continuity of the thermal fuse. Replace it including the cycling thermostat if the thermal fuse is indeed open. Click on the links below for more detailed troubleshooting.
Dryer Not Starting
Dryer Not Starting
Note: Some dryers use a thermistor in the absence of a cycling thermostat.
Kenmore Elite 110.65964401 Electric Dryer Bulkhead Parts Diagram
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice.
Posted on Jul 09, 2011
Neptune dryer not starting
Yes, I recommend you type in "Sears Parts Direct" to your computer search engine.
Put in your model number in the box, and you will see schematics that will answer your questions.
God bless your efforts.
Feb 26, 2016 | Maytag Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer quit working - will not do anything when "start" button is pressed
It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
May 12, 2009 | Dryers
Start button doesn't start the dryer
see if the drum is jammed if not replace the motor
Mar 31, 2009 | Dryers
Dryer will not start
Forgot to check the thermal fuse. Now working after changing fuse.
Mar 21, 2009 | Kenmore Dryers
Whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Start button pressed in and now won't start
you should have a tec come by and take a look thats a five min. job the sping insinde probly broke. hope this can help you.
Jan 02, 2009 | Kenmore 82822 Electric Dryer
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
