Cibox monitor model LT-17S BLANK SCREEN PROBLEM
Hya, my monitor blank off-on and i dont no whats the problem....it works on 60hz
SOURCE: Blank screen
This problem is very often caused by dry electrolytic capacitors on the inverter board. If you have some skill with soldering you could try to change them. When buying new ones ask for LOW-ESR capacitors for switching mode power supplies (SMPS) and 105°C, they are a little bit more expensive than normal electrolytic capacitors, but are designed for this aplications so they lasts more. Normal el. caps will also works fine so when you cannot buy LOW-ESR for SMPS use normal ones.
Posted on Dec 04, 2007
SOURCE: Mag innovision LT716s monitor model 700p blank screen
Have you installed the drivers for it? I had the same problem and when I installed the driver, problem solved.
Posted on Mar 02, 2008
SOURCE: Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Posted on Aug 21, 2009
benwabnick
  • 2404 Answers
SOURCE: emachines monitor model le1987 screen goes blank
Need to verify whether its a monitor issue or a computer issue. Get a known working monitor and hook it up to the computer. If you get video then you know for sure the original monitor is bad.
If you still don't get video then you know its going to be either a problem with the video card or the computer.
Posted on Nov 30, 2009
P0W3R GL1CH
  • 185 Answers
SOURCE: Viewsonic vg2021m monitor goes blank.
the probelm u are having mostlickly the backlight is out on your monitrer. thy CAN be replaced but with all the time it takes and money to do them i sugjest just getting a new moniter.
Posted on Dec 31, 2009
I am in charge of a computer account here at work and have about 15 ACER 1916B monitors that are all inop...The monitors power up and show the ACER startup then show the windows startup to only go...
This problem is caused by 2 things, the computer is set to a higher resolution that the monitors can handle, so when the graphics card drivers kick in as windows boots the screen goes blank, this is normally the problem for people trying to hook there computers to normal lcd televisions not monitors, as monitors generally are able to show higher resalutions.
In your case because you are using computer monitors, the problem will be caused by the refresh rate settings on the windows, most desktop lcd monitors have a fixed refresh rate of 60hz, my guess is your computers are set as 75hz therefore as windows boots the screen goes blank because it dosent support that high a refresh rate.
To resolve this problem, just before windows boots press F8 on the keyboard, this should bring up a black command prompt screen, at the top you will see the safemood option, tab up to it and press enter, this goes to windows but dosent load any drivers including the graphics driver. Once loaded right click the mouse in the middle of the screen, and bring the display properties window up, in this window click on the settings tab, click on advanced on the bottem right of the window, this will bring up another window, click on the monitor tab, on this window you will see the screen refresh rste setting, click the small arrow and set this to 60hz and click ok, in the other window reduce the resalution down abit using the slider, click apply and close the window, then reboot the mechine as normal, the problem should now be sorted, any problems post me back. thanks and hope this helped.
Sep 22, 2010 | Acer AL1916W 19" LCD Monitor
I have a blank screen. Only when I press menu do ...
Me too... If I put it on 640x480 it also complaines that it want 1280x1040@60hz but there is newer a picture eaven if I give it that resolution...
May 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
I have a samtron 74v and upon booting up the screen stays black and a message flashing across my screen says "no optimum mode, recomended 1280 x 1024 : 60hz" but how can i change the resolution and...
Running XP? Boot the PC in safe mode (hit F8 key while PC is booting up and select safe mode), then set the video resoltuion to 640 x 480, reboot into regular boot up, reset the video resolution to 1280 x 1024 @ 60Hz.
Mar 19, 2010 | Samtron 74V 17" LCD Monitor
Xp os i make a misstake full resolution and screen is blank plz help me lg lcd 32 inch
reboot PC in save mode and set the resolution to 640 x 480 @60Hz, reboot in normal mode and reset the resolution to the native resolution of the monitor (you need to find out what that is in the monitor owner manual).
Mar 09, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor does not want to come on
Twelve years is a lifetime for a monitor.
May 15, 2017 | KDS 17S 17" Monitor
Try to adjust the frequency.
Right click on desktop , properties, (my windows is in portugese. Dont remember the right name) configuration, button "advanced", display.
I hope to help u.
Good luck
Dec 17, 2007 | CTX PL 9 19" CRT Monitor
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
