Question about Craftsman Garden
Craftmen dyt4000 what type of oil in trans on a dyt4000
  • chris killeen
    chris killeen May 11, 2010
    model #dyt4000 doesn't work. could u check it and let us know? thanks.
  • 163 Answers
The manufacturers fluid recomendation should be written on the fluid cap or in your owners manual. if not most reecomend a 10W-30 synthetic blend
Posted on Nov 30, 2008
My craftsman dyt4000 will not start,battery is good turn one time and the starter smokes
if its a kohler motor replace the cam shaft
Briggs motor check valve train and or adjustments
to much oil in motor?
Bad starter
bad starter gear
bad gear on flywheel
Oct 11, 2014 | Garden
Have a craftsman dyt4000 riding mower and it will not free wheel, backed off the brake but still will not move. Any suggestions on what else I can do.
if it has the automatic trans you need to pull the rod on the rear of the machine that if for free wheeling the machine
Jun 23, 2012 | Garden
Change tire on dyt4000
the cover just pulls off there is a clip under there that holds the wheel on and a lot of time the wheel gets stuck to the axle and then i change them right on the mower
Apr 22, 2012 | Garden
What type of gear oil is used for a 95 toyota camry
In a manual trans it is API GL-3, GL-4 or GL-5 75W-90 gear oil, for instance Shell Transaxle Oil or Mobil Delvac.
In an auto trans the diff is the same grade fill as the trans, Dexron III.
Dec 03, 2011 | 1995 Toyota Camry
I need to know what type of oil and transmission fluid this car takes.
This vehicle takes 5w-30 weight oil and dextron 3 trans fluid.The types are on the oil cap where you fill the oil and on the trans dip stick where you check the level.Do not over fill it and make sure to check the trans fluid level with the car in park and engine at operating temperature.The oil level always check with a cold engine.May also be checked warm but may read slightly low.Hope this helps.Good luck.
Oct 21, 2010 | 1995 Oldsmobile Cutlass Ciera
Hydro trans slips on dyt4000 craftsman
I'm having the same problem on a 200 and have narrowed it down to belt slippage. Problem is I replaced both pulley's and belt with Sears parts and made it worse. You can pull back on the brake/clutch pedal and it doesn't slip but there is no adjustment I can find. ANYONE got a CLUE
Apr 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a dyt4000 craftsman riding mower just got
recharge the battery
pull the plug and see if there is any oil in the cylinder
fix the oil leaks
OR
get a new motor 20 hp from e-bay for a good price that just bolts straight in
that way you will have a trouble free mower for the price of a new engine
remember you got it free and that means that is is not a good proposition to repair
Dec 02, 2017 | Briggs & Stratton Briggs Stratton Intek V...
How to change the automatic gearbox oil - Seat - Cordoba - 1996
There will be a plug on the bottom of the transmission casing to let the old gearbox oil out.
On an automatic trans the filler is usually on top at the trans dipstick.
On a manuel trans there is a plug about half way up the trans casing.
Drain fully and put in correct type and amount according to your manual. Do not put any old trans fluid in use the type and quantity recommended by the manufacturer!
I find myself just going to a Quick Lube Shop and letting them do it for a few bucks more.. They get it right and it's faster than me doing it myself.
Hope this will FixYa!
jack
Feb 07, 2009 | 1996 Volkswagen Golf
Garden Logo
207 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
