Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
The basin will fill just fine at the the start of a wash cycle but once it drains and the rinse cycle begins, it will not fill with water nor does does water emit during the high speed rinse even though the center unit will spin. Would like to repair if possible . . . machine is only 5 - 6 years old.
  • Anonymous Mar 22, 2014
    water does not start filling basin when switch activated
  • Anonymous Mar 29, 2014
    Does not drain
    Genius:
  • 1,028 Answers
Most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Posted on Oct 25, 2008
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Won't stop filling basin and doesn't agitate.
check your pressure level hose. it probably pulled off at the tub or the pressure switch
May 18, 2009 | Hotpoint VBXR1090D Top Load Washer
No pressure during wash cycle
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 | Dishwashers
check capacitor on motor. possibly not turning at correct speed
Jun 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,144 people viewed this question
Dan Webster
Dan Webster
Sal De
