Question about Sony PlayStation 2 (PS2) Console
I connected my playstation 2 to a Samsung Synmaster P2770HD TV Monitor and it plays in black and white. How do i fix this?
SOURCE: Connect Playstation 2 to computer monitor
try going to your local radioshack and asking for a cable to do it. Tell them it needs to be "double male" infering that the piece sticks into another part instead of bieng stuck into. Then tell them one end needs to be "RCA cables" (the red white and yellow ones) and the other end needs to be a computer moniter cable. There are several types of moniter cables you can use, look in the back of your moniter to see what you have. There should be writing that says any 1 of the following "s video in", "dv in" "video in" etc. ask the radioshack man to get the non RCA side of the cable to have one of these on it. If you need to, it helps to take a picture of the back of the moniter where all the input plugs are, and show it to the radio shack man, he can probably help decide which cable to use. Once you buy the cable, plug the red yellow and white side into the red yellow and white holes respectively on the PS2, and the moniter cable into the moniter. Turn on the moniter and the PS2 and... Voila. PS You may need to take out the cable connecting the moniter to the PC to put in the new radioshck cable. I hope this works for you-BCA
Posted on Aug 26, 2007
johnny_20
  • 161 Answers
SOURCE: Playstation 2 pal to ntcs
There should be a way to switch the your T.V. from NTSC to PAL. It should be easy. Yes you can play music on the ps2, if it's on a compatible dvd or cd.
Posted on Jul 24, 2008
  • 5 Answers
SOURCE: original games are displayed black & white
plese check your tv work on pal or ntsc system, couse any game play with pal or ntsc
Posted on Jan 12, 2009
  • 125 Answers
SOURCE: my playstation 2 only plays in black and white,is
You need to check the inputs on your TV. You might have the PS2 connect to the GREEN Component IN on your TV. Try changing it to to YELLOW connector and selecting VIDEO on the TV.
Posted on Apr 18, 2009
  • 15 Answers
SOURCE: playstation 2 is in black and white
ps2 goes black and white on plasma tvs
Posted on Nov 01, 2009
What causes a picture to disappear on the TV, but you can still hear the sound?
The sound and the video are produced by 2 seperate boards. One board which provides the sound is directly connected to the speakers. The other board will be the power converter board which controls your graphics. Since there are only 2 boards in a FLAT screen TV it should be the one with 4 to 8 little transformers (a coil of wire) mounted to the board and not connected to the speakers. You can then look up a video board for your model. Should cost $40 to $160. Its all just unscrew the old board and unplug each plug and replace with the new.
Bill
Sep 27, 2016 | Samsung P2770HD 27 inch Widescreen 1000:1...
How can I fix a synmaster b1630 monitor that has green tint on screen now?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 27, 2014 | Samsung SyncMaster Computers & Internet
I HAVE A LCD TV MONITOR, MODEL P2770HD, AND I CAN NOT FIND HOW TO REMOVE STAND FROM TV. SOMEBODY PLEASE TELL ME OR SHOW ME. RON
bobhifi_23.jpgIn the area marked by the yellow line you will find four black screws.Keep the monitor on the floor & remove the screws. now keep both your toes on the base stand and pull up the monitor. If you do not want to stamp on the base ask somebody else to hold it down while you pull up the monitor. Make sure you do not apply any pressure on the front screen. Hold the edges of the monitor
Mar 28, 2011 | Samsung P2770H 27 in LCD TV
When I connect my Playstation 2 to my samsung tv the video appears in black and white. How do I rectify this?
in this case it would seem you are watching in nstc you need to switch the unit to pal using your remote switch the bbc to pal
Jul 08, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Subject: Trouble shoot Samsung Synmaster 151 MP LCD monitor Hello, I have a NTSC compatible DVD player, (pioneer DVH-P7000) linked, pictured communication via S-video to the sumsung LCD, also NTSC. It is...
S-Video connectors have separate luminance (B&W) and chrominance signals.
Your symptoms are those of a bad connection on either pin 2 or 4, those responsible for chrominance signals. Check the connections and the cable. Try gently wiggling the connectors when the image is displaying. A flash of color imagery indicates that it is indeed a bad contact, hopefully in the cable (which can be replaced cheaply).
http://en.wikipedia.org/wiki/S-Video
Nov 02, 2009 | Samsung SyncMaster 151 MP (Silver) 15" LCD...
Playstation 2 is in black and white
Nov 01, 2009 | Sony PlayStation 2 (PS2) Console
Have a Konka TV but ps2 doesnt play through it.
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
My playstation 2 plays in black and white instead of color. How do I fix this?
I guess your console is NTSC and your TV or the display you connecting your playstation to is pal or vice versa
you would need NTSC to pal converter if there is no color on the display
Dec 18, 2008 | Bethesda Softworks Black & White
Samsung SyncMaster 750S
1. check tha VGA cable is properly connected into the computer
2. possibly CRT board dry solder. you can touch up the solder joint
Apr 17, 2008 | Samsung SyncMaster 750S Monitor
Synmaster 740 n green line on the monitor
This may be part of the OSD (on-screen display). If you don't have your manual you can download it here: http://tinyurl.com/yzerbd I would check the manual.
Jan 07, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Sony PlayStation 2 (PS2) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
