Tone arm falls short of landing on record - Audio Players & Recorders
SOURCE: tone arm lifter is missing
I shopped around thanks.
Posted on Feb 09, 2009
  • 133 Answers
SOURCE: tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Posted on Sep 16, 2009
SOURCE: When I push the start
Click on the link below and view pictures and instruction on how to adjust your Denon DP-47F turntable:
http://www.audiokarma.org/forums/showthread.php?p=4192169
You can download a free copy of the service manual, click on the link below:
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Dec 05, 2010
SOURCE: My record spins fine when
It would appear you have a problem with the "Cuing mechanism" this is quite a common problem. This link below will assist you to understand about it.
http://www.turntablebasics.com/advice.html
What you need to do is locate a service manual for your exact make and model, in there you will find the necessary troubleshooting steps to take to isolate and cure your issue. However I have had a look and have been unable to locate any, perhaps a direct approach to the manufacturer may yield one?
It can often simply be a faulty switch, the "Mode Switch" this is simply replaced, however to obtain this one ,must have the parts number, the ONLY place this is available is in a service manual. Sometimes it is the belt or drive? it is usually something quite simple, often it's obvious once the TT is disassembled.
should you not wish to DIY, simply find a competent Turntable repair place and ask first for a "Quote" once appraised of the costings etc, then go from there.
http://www.ehow.com/how_2086746_troubleshoot-turntables.html
http://www.audiokarma.org/forums/showthread.php?t=37752
below is a link for the user manual...
http://www.crosleyradio.com/Manuals/CR249_Manual.pdf
http://www.vinylengine.com/library.shtml
Above are a couple of sites that may help you if you wish to DIY?
Posted on Aug 18, 2011
STYLUSCITY
  • 271 Answers
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Posted on Nov 11, 2011
When I play a record, and the gripper arm is in front the tone arm lands on the wheel and does not land on the 45
Some decks have a selector switch for 7inch and 12inch records. You need to find it and select the 7 setting. However you will need to switch it back to 12 if you want to play an LP.
Jul 14, 2015 | Audio Players & Recorders
Adjust tone arm
Usually there is a hole towards the back of where the tonearm is mounted that adjusts the set down area. Be aware that some have two holes one for set down and one for pick up of tonearm. These can be adjusted with a flat blade screwdriver. Check and see with a good flashlight. Adjust slowly and check to make sure you are turning it in the correct direction.
Apr 04, 2014 | RCA Audio Players & Recorders
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
Nov 09, 2011 | Crosley 0187SST Turntable
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
My turntable keeps skiping for no reason, no matter the record. i also made sure the turntable was level. the turntable is a vestax 2000mkII
What is the weight on the stylus? Flip the protective shield down to protect the stylus if available. Tare the tone arm (adjust the counterweight on the back of the arm until the arm floats perfectly level), then hold the counterweight and turn the dial markings to read zero. If you cannot find the recommended mass for the stylus you can use the average weight of 3g. Verify your tone arm is still floating in the center and the arm is perfectly level. Turn the counterweight until the dial indicates the specified weight of the cartridge manufacture specification sheet or you can set it for 3g if you do not have the specification sheet.
Nov 23, 2009 | Vestax PDX-2000MKII PRO Turntable
Dual 1229 tone arm sets down short of record start on LP
Isn't there a little knob with a +/- setting that allows you to move the indexing in or out from the edge of the groove? Play with that and see if you can't get it dialed in a little better...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 20, 2009 | Electronics - Others
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
May 20, 2007 | Emerson NR303TT CD Shelf System
27 people viewed this question
 Grubhead
Grubhead
