Question about Aurora Electronics AS890C Shredder
Aurora as890c fixing paper jam
Appears to be jammed.
  • 537 Answers
SOURCE: I just bought my shredder 3 weeks ago and
Did you open up the shredder or remove it from the basket? Look and see if the switch is in the right place and is not being blocked.
If you didn't mess with the switch and just cleared the jam, then take it back to where you bought it for a replacement
Posted on Apr 17, 2009
  • 22 Answers
SOURCE: I have an Aurora as662c paper shredder, I have a
There are 5 screws that you need to remove, 1 of them is hidden beneath a white sticker that says void warranty if removed.
Posted on Sep 08, 2010
  • 12 Answers
SOURCE: I have an Aurora Shredder
Check safety and detection switches. 1. Safety is on the bottom and left or right side of shredder unit inside a narrow gap. On the bucket's wall there is a natch witch should go into the gap, when you put shredder correctly. Check if switch and natch are on the same side. Simple turning around will solve problem. 2. Check a detection switch. It is located in the middle, inside of gap. This switch engages and turns motor on when you put paper into shredder. In other words sheets of paper should push the switch first before touching shredding rolls. If you have digged out that paper from the top side, chances are you have broken that switch.
Posted on Feb 12, 2011
walesarumi
  • 6993 Answers
SOURCE: Hi, my Aurora AS1002MSB is
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck....
Posted on Apr 09, 2011
SOURCE: How do I remove the
There are 7 screws. You missed the one hidden under the small silver label.
Once you take it apart, don't waste your time calling Aurora as you voided your warranty and ability to get help from them. That happened to me.
Posted on Jul 11, 2011
Testimonial: "Thanks for the advice. And I won't even consider calling Aurora - or buying another Aurora shredder."
I have a Dell 5100cn and I'm getting paper jam check tray, it seems that when it goes to pick up the paper it can't
077-907 Paper Jam - Push Side Button:
  1. Turn the printer off using the power switch on the right side of the printer.
  2. Press and hold the up and down buttons while turning the printer on. ...
  3. Press the down arrow until IOT DIAG appears, and then press Select ( or ).
  4. Digital Input appears on the LCD, press Select ( or ).
More items...
How to Troubleshoot Internal Paper Jam or Multiple Sheets ... - Dell...
or try this link...
how to fix paper jam Dell 5100cn Google Search
Oct 27, 2017 | Dell Office Equipment & Supplies
How do I remove the shredder head case of an Aurora AS890C? I have removed the 6 screws (it's unplugged), but it still won't come apart. It quit working, so I don't know if it's jammed or...
May 12, 2011 | Aurora Electronics AS890C Shredder
Hi, my Aurora AS1002MSB is jammed and it will only go in reverse. Is there any way to fix it?
Good luck....
Apr 08, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Got jammed. It will now run in reverse but not in shred mode.
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Mar 07, 2011 | Aurora Electronics AS890C Shredder
If I put the document in straight it won't shred. I can get it to shred if I insert it on the left hand side - there seems to be some kind of jam on the right hand side.
Unplug it first. If you are certain that there is a jam, take the top off and flip it upside down. Use a pencil or other object that is NOT YOUR HAND and try to remove some of the paper jammed up. It is also possible that there is only a sensor on the left hand side. If this is the case there isn't much that you can do. Hope this helps and tell me how it works out!
Oct 07, 2010 | Aurora Electronics AS890C Shredder
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
E3 paper jam
if the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Apr 21, 2008 | Office Equipment & Supplies
Aurora Electronics AS890C Shredder Logo
89 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
