Question about Warmrails & Satin Nickel Towel Warmer & Drying Rack
The wall mount brackets for my warm rails towel warmer have broken.
The plastic gold brackets for the s-shaped warmer.
2 Suggested Answers
  • 10865 Answers
SOURCE: New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Posted on Feb 19, 2009
IT doesn't heat up any more so the towel does not get warm, do you know anything about towel warmers? do they have an element?
Many do have an electric heating element; there may be a light next to the switch which might indicate whether it is on or off. However some are heated by hot water or steam (it seems). You might consider changing the element, try the fuse in the circuit first, it might save you a lot of trouble. If you decide that are able to change the element yourself, get the instructions and only then source the part. If it's wall mounted it's more difficult. However it's probably best to get an electrician to do it as it can be very tricky. I may even be necessary to contact the manufacturer or buy a whole new item
I hope someone else comes up with a better answer !
19.January.2016
Jan 19, 2016 | Mr Steam W542 Heated Towel Warmer W542...
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
I bought towel bars at a yard sale and the wall brackets are missing. Is there any place I can buy the mounting wall brackets?
Yes, Bed bath and Beyond, they have the parts as well as lowels and home depot. Let me know if this helped by posting 4 thumbs. Thanks mike
Jun 12, 2011 | Gatco & Channel& Satin Nickel Towel Bar
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Tryiny to put my Akai LCT3201AD TV on the wall
For a set this size, there should be at least 4 mounting holes for a wall bracket. Please note that wall mounting is an option so the holes may be covered by plastic caps to hide the holes. These holes should be in a box shape around 1 foot wide or so.
Dan
Apr 10, 2009 | Akai LCT3201AD 32 in. LCD Television
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Aug 27, 2008 | Kohler Bathroom Accessory Set with Classic...
Warmrails & Satin Nickel Towel Warmer & Drying Rack  Logo
295 people viewed this question
Top Warmrails Home Experts
john h
Tom Chichester
Are you a Warmrails Home Expert? Answer questions, earn points and help others
