Question about Microsoft Office Professional 2007 Full Version for PC
Corrupted file i created a xls file on my computer at work, saved it to a memory stick, it will not open on my inspiron 1520, message says file may be corrupted
  • Frank
    Frank May 11, 2010
    are you using the same MS Office applicaton at both place??
    files created in MS office 2003 can be open with MS Office 2007 application. not the other way around. In order for MS Offcie 2003 or earlier application to read the files created in MS Office 2007, the file need to save it in backwards comparable format.
    there also a difference between all of the MS applications.
  • 903 Answers
You can download a compatibily pack for office 2007 on microsofts website it is free
Posted on Oct 25, 2008
Gudpm po im asking about how to open my open offices file again..last feb 15 i open my company pc the file has corrupted... tnx.....
If your company was using MS Office 2003 then you're using MS Office 2007. Make sure you're saving the file in a compatible format. For example, if you've create a report on excel file using MS Excel 2007 then you should save the file in .xls (compatible format) instead of .xlsx (2007 format. In that case you can open your file on both versions. Also when you're saving other office files make sure it's in compatible format.
Feb 22, 2011 | Microsoft Office Professional 2007 Full...
How do I down load pics to a memory stick I use a dell inspiron 1520
The download procedure is the same but while saving choose the location as your memory stick.
Jun 21, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
I have a sony psp. I have music stored on a small
corrupted data usually means just that corrupted data and usually won't let you play em at all. you may want to retransfer the files again... and after that if that didn't fix the problem reformat the new memory stick.
what you describe should have been fine. files just might have been corrupted from moving over from one to the other. is it for every song or just one? you could try this without the media go. i have an older firmware since i haven't upgraded my psp in awhile... but
1)on the desktop of your pc create a folder called pspmusic. right click on any blank spot on your desktop>go to new>folder> and rename that to pspmusic
2)plug in your psp to your computer like you normally do using the usb cable.
4)go to your music folder and copy everything in that folder to the pspmusic folder you created on your desktop on your pc in step 1.
5)once that done close that window down.
remove your old smaller memory stick from your psp and insert the new bigger one and connect it to your pc in the normal way.
6)go to the drive of the psp and to the music folder (if there isn't a music folder there create one) and open it. what you may want to do here is to delete all things in there or keep as is. just know that if there is a corrupt file in there you'll have the same problem. this is up to you for you can try this again later.
7)now go to the pspmusic folder on your desktop and copy all the music in that folder and bring it over to your music folder on your psp.
8)once everything has transfered over test it out and see if all works
its a bit more hands on than using media go but at least you see what is happening.
if that didn't work you may want to try formatting your new bigger memory stick
May 01, 2010 | Sony PlayStation Portable (PSP) Console
How do i use a memory stick
How to use a memory stick or USB
I will assume you are using windows. as you can see your USB memory stick has a metal connector with a plastic insert; that was made to fit in the connector on the back or sides of computers. the computer has several places to insert the memory but this device will fit properly in just the correct jack and it will go in in just one position, you can not turn it over and insert it.
after you do that windows will install the driver (software) for the device and it is going to open a window asking what do you want to do at this point you can click on any option but if you want to see your files or save files, click on the folder that says view files.
that opens the device, if it is brand new there would be no files. At that point you can drag all kinds of files in to the memory and store them.
the other option after you insert the memory, close the asking window and click on my computer from here you can see your memory stick, click on it and it will open, drag files to it or out of it in to your computer.
when you are creating documents or files you can save them in to your memory stick. Just click on file--save as--computer--memory stick (name or model)--save or ok.
when you are ready to disconnect your memory stick go to the clock area on the right corner, there is an icon of a connector with a green check mark click on that and then stop device, select your memory stick-stop, wait for confirmation and then you can unplug it >>>>failing to do this may damage your files or memory stick<<<<<<
if it works for you don't forget to rate me
Apr 28, 2010 | Gateway Essential 400 PC Desktop
I downloaded the update but the pc cannot open the file . the updater is called eboot. i have it in my pc but cannot open it
The file is not supposed to be opened by your PC. You have the transfer the file from your PC to the PSP. To do this, you need a USB cable and you have to plug your PSP into your PC.
Download procedure
  1. Prepare to save the update data on either system storage or Memory Stick Micro™ (M2)™ media, using one of the following methods:
    • Connect the PSP® system to the PC using the USB cable
    • Connect a commercially available Memory Stick USB reader/writer to the PC
    • Use the Memory Stick slot on a PC
  2. Create a folder for the update data on either system storage or Memory Stick™ media.
    Using your PC, create a folder named "PSP". Within the "PSP" folder, create a folder named "GAME". Within the "GAME" folder, create a folder named "UPDATE". (Folder names must be in all uppercase letters).
  3. Download the update data for the PSP-N1000 (PSP®go) series and save it in the "UPDATE" folder created in step 2.
You must save the downloaded data as noted in these instructions. If you do not save in the correct location and with the filename shown below, the system will not recognize the update data.
  • Filename: Save as filename "EBOOT.PBP"
Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
When I plug in my Lexar memory stick, and try to save a file to the removable drive (J) which is the memory stick says I can't because it doesn't exist. Help?
Hi, Neil.
Look in "My Computer" to see if another drive letter was created when your memory stick was plugged in. Sometimes, another drive letter is created. Try dragging and dropping the file you want to save.
In case you are not aware, in each computer, the drive letter for a memory stick could be different, depending how a computer is set up.
Also, try in another computer to see how your memory stick works (if it's OK).
Hope this helps.
Oct 25, 2009 | Lexar JumpDrive Classic Portable USB Data...
I have purchased a memory stick[8GB] and I need to know how to use it
Hello !
If you are familiar with floppy disks (were placed in the "A" drive) from years ago, the memory stick works in the same way. Instead of saving to the "A" drive, you would save to a drive letter.
If you have a computer that is less than 8 years old, you probably have a USB port. The USB port is rectangular in shape.
Place the memory stick in your USB port (any USB port). The stick only goes one way. So if it does not fit, flip it over and try again. Do not force it.
You should see a message displaying a drive letter (probably "E", "F" or "G") that has been created. Note that drive letter.
Now, the memory stick will allow you to save your files to the "E", "F" or "G" drive. Your computer's hard drive is "C". When you save files (in a document, for example), you are saving to your "C" drive. To save to the memory stick, select "Save As" with in your software program, such as Word, and select the memory stick's drive letter. Your document will be saved to your memory stick. Note that the light will go on the memory stick as it saves your document.
When you are finished with the memory stick, look for a symbol on your Toolbar (near the date/time). Right-click the item and select "Eject" and you'll get a message that it is safe to remove your hardware.
Please note to never remove your memory stick when your are saving a document or other file.
That's it !!
Hope this helps.
Oct 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Repair corrupt excel file
Don\'t need to worry even if your excel
files are get corrupt because there are several ways to repair
corrupt excel files. The easiest available solution is to use "Open
and repair" utility of MS excel to repair damaged xlsx or xls files.
Jul 10, 2009 | Microsoft Office 2003 Professional Full...
Excel files couldnot opened
It is because your excel file is get corrupted. There are several reasons of excel file corruption; virus attack is main reason of corruption. You can fix this problem with the use of "open and repair" utility of MS excel or you can use Excel repair tool .
May 05, 2009 | Computers & Internet
I want to save an email message to my memory stick but pc wont do it
Please follow the following steps to backup your emails from Vista on the
memory stick and then download them on in Vista Mail of another PC:
Backup emails on memory stick
1) Browse to the C:\Users\<username>\AppData\Local\Microsoft\Window s Mail
2) Open the local folders directory
3) Open the Inbox folder and Copy the contents of this folder
4) Close all windows and go to your desktop
5) Create a new folder and call it MSBackup
6) Paste all items into this new folder.
A manual backup of the message store has just taken place. You may now
simply copy the MSBackup Folder to your memory stick
Restore emails from memory stick to another PC
1) Copy the MSBackup Folder from the memory stick to desktop.
2) On the desktop, open the MSBackup Folder.
3) Copy all the items in the MSBackup folder and close the window
4) Browse to the c:\users\<username>\local\windows mail\local folders
5) Open the Inbox Folder
6) Paste all the items into this folder. Choose yes if prompted to
overwrite folders/files.
7) Open Windows Mail. You will notice all the email messages have returned.
Let me know if this works.
Apr 29, 2009 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
