Question about Royal VF-1200MX Shredder
My shredder requires about an hour of cool down every time it shreds a load.
My shredder require a long cool down time every time I turn off the power to empty the basket. I do not overload the feeder. Shredding documents becomes a three day process.
    Scholar:
  • 75 Answers
Do spry lub down in the cutter shoot like WD40. If not do it. If you do there may be a billed up of paper dust in the machine it is a catch 20,22
Posted on Oct 25, 2008
Fellowes 60c shredder is jammed, can't get little bit of paper out and it won't work in reverse or forward
Some office shredders have a removable mechanism; others require removal of the bin followed by turning the unit upside down to get access to the mechanism. In any event, with power disconnected the next procedure is to remove the shreds of paper jammed in the mechanism. This is a long, tedious process requiring perhaps tweezers, needle nose pliers and infinite patience. Eventually, the shredder will work again (unless the motor has burned out).
Mar 21, 2014 | Fellowes Office Equipment & Supplies
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
This shredder overheats after 1 to 2 thin weight sheets of paper. Says it does up to 10 sheets but can not handle more then 1 sheet at a time. I have cleaned and cleaned the cutters with no improovement
Have you "oiled" the machine ever.????
Cross-cut shredders require occasional oiling with "shredder oil" to help clear out debris that is made in the shredding process from the cutting mechanism. Get some shredder oil and pour it directly across the cutting blades where you insert the paper... this should help...the occassionaly pour some oil onto a sheet of the paper to be shredded prior to shredding it.
Oct 28, 2010 | Royal VF1000MX Shredder
The overloa light comes on and the shredder stops immediately. the hopper is empty and there doesn't appear to be anything blocking the shredder. i was shredding for about 1/2 hour when this started. i've...
You have probably "fried" the pcb inside the machine.....this is a "consumer" machine...no more than 5 mins ON then 10 Mins OFF to let it cool down.....you should only shred about 70% of the MAX rating for the machine.
For Parts advice call Royal at 1-800-524-0799.
Feb 13, 2010 | Royal VF1012mx Shredder
How do I remove excess EXCESS oil from my shredder? It won't shred.
Asking why you should keep your shredder lubricated is no different than asking why you should change the oil in your car every 3,000 miles. Not only is proper maintenance a requirement to maintain an active warranty, but all mechanical parts need a little oil to help them turn smoothly and to keep them clean. Applying shredder oil to the cutting heads inside a shredder lubricates them so that they efficiently destroy documents sheet after sheet. Fortunately, you will find that taking good care of your shredder is less expensive, faster and easier than caring for your car.
Every time you shred a sheet of paper a fine dust made of tiny paper particles is produced. This dust collects in the cutting assembly of a paper shredder. If allowed to build up, this dust will compact until it completely blocks the smooth turning of the cutting head. Shredder oil will actually break up the compacted dust lodged in the cutting assembly, allowing the parts to move and push out the softened dust.
Shredder oil is specially formulated to eliminate oil residue on the cutting head. Other oils, like WD-40, will attract dust, further clogging the cutters. When lubricating your paper shredder, only use oil specifically designated for shredder use or risk voiding your warranty and further clogging your shredder.
The frequency with which you should oil your shredder depends on several factors: frequency of use, shredder capacity, cut size and type of paper. Your shredder will need more oil the more you use it, the more paper you shred at once and the thicker the paper is that you shred. Also, shredders with smaller shred sizes require extra oil. A 1/4" strip cut shredder used only one to two hours per week will only require a weekly oiling. A cross cut shredder, on the other hand, requires oil after every half hour of use. If you remember to oil your shredder every time you change the bag you'll be in good shape.
There are two fast, easy ways to oil a paper shredder:
The first method involves applying the oil directly to the cutting head. Shredder oil is packaged either in plastic squeeze bottles or aerosol cans, designed for easy application. No tools are required, just aim the bottle directly at the cutting head, through the paper entry point, and apply a fine stream of oil from one end of the cutter to the other. Run the machine in reverse for 10-15 seconds until the entire cutting mechanism is coated. Finally, shred a few pieces of paper to remove any excess oil from the cutters.
The alternative method requires streaming oil onto a piece of paper. Do not soak the sheet in oil, but cover it evenly from edge to edge. Shred the oiled sheet of paper and then run the shredder in reverse for 10-15 seconds to allow the oil to coat the entire cutting mechanism. Finally, shred a few sheets of paper to remove any excess oil from the cutters. In any case, run a couple of sheets of paper through the shredder after oiling to remove excess oil. procedure may be repeated up to three times to ensure proper lubrication.
If you take a few seconds once a week or every time you change your shredder bag to oil the cutting mechanism in your paper shredder, you'll maintain your warranties and keep your shredder running smoothly and efficiently document after document.
click this link directly for more detailed help
---- http://www.howtocleanstuff.net/house/appliances-and-fixtures/how-to-clean-a-shredder/ --------
thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 22, 2009 | Royal 1280MX Shredder
Won't Turn on
Yes...these small shredders are only meant for light use....5 minutes ON..10 mins OFF to let it cool down, thats the nature of a $60 or $70 shredder.
Commercial shredders start at $250 and go up. But you dont have to wait for them to cool down.
Common sense still says you must buy the right machine for the job...even if you only use it 2 times a year..it depends on the amount of paper you shred..not the number of times you use it.
Anyway...if it won't turn on at all its most likely the pcb inside....contact Royal for parts and pricing at 1-800-524-0799.
Jun 06, 2009 | Royal AG10X Shredder
Turns on when paper in slot, but won't pull it through to shred.
must disassemble feeder unit. you will find many bits of shredded paper to pull (push) out with a long narrow tool like a crochet needle.
Jun 19, 2007 | Royal AG10X Shredder
117 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
