Beko washing machine 5kg a+a class 1000rpm wm5100w
The buttons on the washer are stuck and it wont cancel programe or do nothing
4 Suggested Answers
  • 6277 Answers
SOURCE: I NEED AN OPREATING MANUAL
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 08, 2011
Testimonial: "thanks yes i got it eventually , it was for my friend thanks gill"
  • 6277 Answers
SOURCE: beko washing machine a+a class
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 10, 2011
  • 6277 Answers
SOURCE: beko aa class 1000rpm wma 510w washing
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
John C
Posted on Sep 05, 2011
When I press start the electricty trips ?
u HAVE A SHORT SOMEWHERE AND NEED TO CHECK UR WIRING FOR BURNED OR FRAYED AREAS.
Dec 16, 2014 | Beko Washing Machines
I need beko aa class 1000rpm operating manual
Hi Edwin, good day! For that specific brand and model, you can actually check this link for the file and download it from there:
Beko Automatic Washing Machine Installation Operating Instructions...
Sep 22, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
I NEED AN OPREATING MANUAL FOR A BEKO WM5100W.5KG A CLASS 1000 RPM
Good luck,
John C
Mar 08, 2011 | Washing Machines
Hello, I have a beko wm5100w and it seems to be stuck trying to pump out water. I have cleared the filter and pipes, but now I need to reset the machine. I have done the "switch off, turn to 90...
It could be a faulty thermistor (showing high temperature)
or water sensor fault that is causing the pump to run.
Just try and unplug it for 3-4 hours, and see if it resets itself,
if not replace sensors, and if that does not work, replace the main board.
Here is the manual:
http://laundry.manualsonline.com/manuals/mfg/beko/wm5100_1.html?p=21
This is the actual reset/diagnostic mode
https://www.youtube.com/watch?v=8C4J3leArY0
https://www.how-to-repair.com/help/beko-wm5100w-wm5100s-test-mode-and-error-codes/
Sep 05, 2017 | Zanussi F1045W Front Load Washer
I can hear the water going into the machine but after after a short while the machine stops, the start pause button and the wash button flash and the machine stops. I have held down the start pause button...
Not an answer to your problem but i am having the same problem with me 20 month old beko machine - a different machine to yours. I have had an engineer out twice already paid for by myself to rectify the problem and now it has happended a third time. The engineer seems to think it is poor quality wire used. Good luck let me know how you get on.
Sep 29, 2010 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Sep 05, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
