Question about Plumbing
Graff kitchen faucet vintage 4120 has constant drip and now has water pooling at handle swivel
jgwhomeequip
  • 1902 Answers
SOURCE: price pfister faucet handle drops and turns off.
There is a price pfister little emblem under neath the handle. Use a but knife and pop that off. Once that is off there is a allen bolt in there. Tighten it up, put the emblem back and away you go
Posted on Feb 14, 2009
  • 659 Answers
SOURCE: dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Posted on Mar 16, 2009
  • 659 Answers
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Posted on Apr 06, 2009
frcs68
  • 1605 Answers
SOURCE: single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Posted on Apr 22, 2009
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
My Graff kitchen faucet just started leaking slowly. What needs to be replaced.
it depends on the type . if new enough it probably has cartridge if old it probably has washers. this is one site I found http://www.chicagofaucetshoppe.com/Graff_Faucet_Parts_s/8628.htm
Jan 22, 2015 | Graff Plumbing
Remove the handle from graff kitchen prescot faucet- stuck
you may have to use a little force gently pry under the handle be extremely careful not to break handle i usually take a piece of wood to put up against faucet or whatever and then tap faucet with hammer then start prying back side with a screwdriver or small breaker bar use your hand to try to wiggle the handle
Aug 30, 2014 | Graff Plumbing
How to repair a constant drip on Hansgrohe Talia (hot water handle)
Most likely you will need a replacement cartridge to resolve a constant drip. This model uses the M2/M3 cartridge part number 92730000. It is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Dec 04, 2012 | Hansgrohe 06649860 Solaris Single Hole...
My Delta 174--WF has a constant drip from the faucet. I'm not sure how to take it apart to fix it, or what parts to replace. Can you help?
Turn off water supply and use allen wrench to remove handle then remove bonnet nut then remove internal parts replacement kits available at most lowe's and other home improvement or hardware store or plumbing supply stores take care to document how everything is removed so you can reinstall exactly how it came out.
Jun 06, 2011 | Delta Faucet Delta 174-WF Waterfall Single...
How do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
I have a Mico 7777 Kitchen faucet that was purchased in 2001.It has become difficult to move from side to side. Do we need to replace the cartridge in the faucet and if so how much does it cost and how...
it may not be nesesary to replase the cartridge you could just have some lime or sediment build up in the faucet a bad cartridge would effect your handle not your spout turn the hot and cold water off under the sink,pull the bonnet or cap off and the spout should just lift up take care not to damage o-rings pulling and reinstalling spout check for debris clean and replace spout to insure not damaging o-ring try putting a little vaseline on them 1.it will help go on easier 2.it will help to lubricate the swivel of the spout replace the cap turn your water back on. if your cartridge is bad your faucet will drip or constantly run
Apr 07, 2009 | Plumbing
Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Plumbing Logo
50 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
