13inch tv/vcr no fast forward or rewind buttons how do you do these
Vcr seems to be in fastforward and there are no buttons to change into or out of fastforward or rewind.
    Problem Solver:
  • 15 Answers
No clicker with it??? if not ,u can get a universal remote that might run it if u dont have one?? they are like 4.00 at walmart and onthe back of the tv there are numbers or a code u put into the universal remote that u purchace , u progam them into it and it will run ur tv..or vcr..like the original would.... if not its in ur vcr...
Posted on Oct 25, 2008
Magnavox tv lost pause, rewind buttonstv problems
This simply sounds like a "remote address" problem, in other words--the remote is not assigned to the set. If this is for a DVD or VCR, you might have to assign that function before they work--by pressing the "dvd" or "vcr" button before they work.
Oct 02, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Why does my vcr play, fastforward and rewind for 4 seconds then stops for no reason?
When the mechanism is damaged the VCR will attempt to play and then shut itself down to prevent any further damage. If you remove the top cover and look around inside you will probably find the cause of the failure.
Aug 10, 2014 | Panasonic Televison & Video
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Ineed a manual for a Fisher VCR
This may help.
Hold down tv power enter the 2 digit code using number buttons 0-9 then release tv power button
Admiral 05, 10 13 - Emerson 17 - Fisher 03 – GE 07 – Gold Star 01 – Hitachi 02 – JVC 15 – Magnavox 08 – Matsushita 12, 18 - Mitsubishi 14 – Panasonic 12, 18 - Quasar 12, 18 – RCA 06 – Samsung 16 – Sanyo 03 – Sharp 00, 13 - Sony 11 – Technolace 05 – Toshiba 04 – Zenith 09,10
And now the impossible clock setting. Turn unit on press clock while holding down the shift button. Press fast forward or rewind to change hours, then press adjust while holding down shift button to select the minutes again use the fast forward or rewind arrows to change minutes then again the adjust and shift combo to start clock.
Good luck Kevin
Fishers help line is 1-800-421-5013
Jan 29, 2008 | Televison & Video
Button mixup problem?? HELP PLZ!!
it requires a switch block assembly. this part includes the keyboard for play, rewind etc.. part # is 1-477-084-31 part should run you about 30 bucks. Larry
Sep 18, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Apr 04, 2006 | JVC HR-J461MS VHS VCR
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
