Question about iLO 3200 32 in. LCD Television
PS3 Hooked up PS3 via hdmi cable to tv cant get it to come on tv went thru every mode.
Bad cable or bad port on tv. Test it. Get another set of HDMI and test it to see if it works. If it doesn't then the port on your tv is bad.
Posted on Oct 24, 2008
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
Ps3 tuning
Hello!!
Try connecting the PS3 with the different cable ... i mean the problem may lies with cable ... So give atry once ..
Jan 03, 2008 | Televison & Video
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
Went from HMDI to standard cables=no picture and no sound
reset your settings on the ps3 on your old tv using the same set up then go to the new tv and it will come on. I had the same prob
Apr 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
iLO 3200 32 in. LCD Television Logo
154 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
