Question about Sakar 3-in-1 1392948 Digital Camera
It doesn´t display the number of photos left
Hi, I already charged my camera 4 hours, and when I turn it on it display 000, and I read the manual, and there, it says that´s ´cause I can´t take more photos, and it chould be displaying 025. When I plug it to the PC, it shows 025, and I can take photos. When it isn´t plugged, I press the shutter button, and I hear like a buzz, like it says in the manual, but the number in the screen increases, like 001, 002, 003, etc. And then I turn it off, and turn it on again, and the screen shows 000 again. What can I do??? Please Help!!!!!!
When i open my camera to take a picture all i get is a black view. i cannot see anything on the display or through the view finder.
Does your camera also have an optical viewfinder? If so, chances are that you accidentally pressed the button that turns the screen off to save battery power. You would then use the optical viewfinder in its place. For your model camera, read the user manual to find out where this button is. On Canon cameras, it's usually a little button labeled DISP or DISPLAY. Just press it oonce to turn the screen back on again.
But if the above doesn't help, have you tried downloading photos taken when the screen is black? Are these photos also black? If so, chances are in this case that you are experiencing a stuck shutter. This is also very easy to remedy (see this).
Sep 05, 2011 | Cameras
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
E18 TO LEFT TO DISPLAY. The camera is blocked.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Jan 10, 2011 | Canon PowerShot A75 Digital Camera
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 05, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Manual too difficult
It seems to me, after reading the Operating Instructions, that it's not possible to stamp the photos automatically while taking them (EXCEPT for when stamping TRAVEL DATES - see below).
What you can do is enter the Play mode, the stamp the photos manually- 1 to 50 photos at a time.
To do this, kindly look on pages 66-67 for detailed instructions (with illustrating images).
Be sure to set the correct time and date prior to stamping the photos. Look on page 16 for further instructions.
If you're taking pictures during traveling, you can set TRAVEL DATE, which will also have a reference to the day number of your travel (page 48).
Hope you'll find my information useful...
Good luck,
Pelu.
Apr 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Fuji camera screen does not display picture even when screen is turned on when taking picture. but screen shows picture when you view pictures already taken
Hi dear, you need to see the manual (http://www.retrevo.com/support/FujiFilm-S700-Digital-Cameras-manual/id/2488ag805/t/2/)
Some camera only use viewfinder to shoot photo,The LCD is for setup and display photo only.Because it's off it will save a lot of battery power so that you can shoot more photos.Check it out in the manual.Have FUN!
Jan 21, 2010 | Fuji FinePix S700 Digital Camera
I dont have the unlock code to my SEAT IBIZA car radio model 1999-2002. what should i do?
I have a SEAT Toledo, year 1999. The radio has been blocked ever since the battery was changes 6 weeks ago. I have the code but on the LED I see only "SAFE". The "PROG" button will not work. How can I unlock the radio and use it again?
Aug 19, 2009 | Volkswagen Car Audio & Video
Deleting photos from camera
For the Powershot A560:
1. Turn on the camera in playback mode.
2. Select a picture using the right or left arrow buttons on the back of the camera.
3. Press the button with an icon of a trash can.
4. A menu comes up:
Erase? Erase Cancel
5. Select "Erase", then press "FUNC. SET."
Page 18 of the Powershot A560 basic manual also explains how to erase individual images.
Page 73 of the advanced manual explains how to erase all images.
You can download both user guides here.
Jul 20, 2008 | Cameras
Digital camera photosmart r725
it wont open when power is turn on,i keep getting ,(camera has experienced an error)(please reset your camera)this number accompanies the message-00000018-4489-957-000,ive read the manuel nowhere does it say how to reset, help ?
Dec 13, 2007 | HP Photosmart R727 Digital Camera
Sakar 3-in-1 1392948 Digital Camera Logo
52 people viewed this question
Top Sakar Cameras Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
