Home | Microsoft | Xbox 360 Console | 3 red flashing lig...
Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
3 red flashing lights on my 360
By kingkersh on Oct 24, 2008
3 red flashing lights on my 360 help please
Same Problem
Apr 23, 2009
-   when i turn on the console,three lights come on. and it dont show any thing on the screen and every thing is hooked up right.i did try to take my hardrive and nothing happens but three red lights on my 360.the power comes on because the GREEN light comes on nd it is still is green.-   skoolrokz200
Apr 23, 2009
-   i love my xbox and like all of you i love to play it. but today i got home from scool and i turned it on and i have three red lights i cant even get to the mainscreen...so when i saw the lights i dove off the couch and turned it off.. i dont want to not play a game for 3-4 weeks so i need some help....thanks eveyone-   xbox974638
Feb 08, 2009
-   my x box 360 is flashing 2 red lights. the last time this happend it was ok but now it wonteven go into the x box mainscreen! i need help.-   Guest
Nov 17, 2008
-   I have 4 red flashing lights on my 360 consol-   Tristangvs
Nov 17, 2008
-   1 red light -   Guest
Best Solution
posted on Oct 24, 2008
Very Helpful)
fixyaixya
Rank: Wiz
Rating: 82%, 26 votes
This is called the 3 rings of death and is well known amongst xbox users. including me... Ive had 1 xbox replaced because of it. Try the following to diagnose the issue. All four lights illuminate = 0
One Light = 1
Two Lights = 2
Three Lights = 3
Example:
Turn on your "dead" xbox. Wait for the 3 red lights. Once you get them hold the "Synch" (for the wireless remote) button and the eject button down simultaniously. All four lights flash. (0) Press the eject button again and only one light (1) press again and all four light up (0) press again and two lights (2). Error code is 0102. compare this code to the table below to find out what is wrong with your X360. Is it overheating? Power Cord? Hardware? what ever the code is refer to this list for the reason it is flashing...
The Code he got was 0102 which means the computer does not know the problem as it is not hardware or heating or anything like that. Could be dust, loose solder or static! He used a can of compressed air and his X360 IS BACK!!!!!! He did not know for how long but he played several hours after and had not one Hiccup. This after a whole week of the dreaded RINGS OF DEATH!!
Here is the list
0001 power supply problem
0002 power supply problem
0003 (not yet known)
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 (not yet known)
0022 GPU Error / GPU Overheating
0101 (not yet known)
0102 unknown error - literally means the console does not know what is wrong. Possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
0110 Memory Error / Memory Overheating
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a currupt or missing Eprom.
1013 (not yet known)
1020 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1030 (not yet known)
Here are some other codes they posted!!
Sections 1, 2, 3, and 4 are flashing red
- The AV cable cannot be detected
THINGS TO TRY
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Sections 1, 3, and 4 are flashing red
- General Hardware Failure
Check the secondary Error Code per the instructions in the section below
THINGS TO TRY
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
Sections 1, and 3 are flashing red
- Overheating
THINGS TO TRY
Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
Verify that the console has sufficient ventilation and that the fan is operating. For more information about ventilation, see the "More Information" section.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
Do not block any ventilation openings on the Xbox 360 console.
Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Comments:
Oct 24, 2008
- get back to me when you find the code and let me know what it is. We might have a solution unless it is what i think it is.....
memory failure from over heating.
Was this helpful?
Yes
No
Solution #2
posted on Nov 14, 2008
Very Helpful)
petraman7
Rank: Guru  Microsoft Expert
Rating: 86%, 292 votes
Also known as 3RLOD...this is directly related to the heat sink clamping method that M$ stupidly designed into the system.
If you can do without your Xbox for 6 weeks AND you still have it under the extended 3 year warranty, then send it to Microsoft.
If it's not under warranty , find someone who fixes electronics and have them go to www.llama.com
He has a very detailed step-by-step way of opening the 360 and what you need to do to fix the 3RLOD
I've taken care of 2 for 2 like this already.
I get $100 per unit.
Was this helpful?
Yes
No
Solution #3
posted on Nov 11, 2008
Somewhat Helpful)
markfishwick
Rank: Apprentice
Rating: 81%, 8 votes
my x box360 has 3 red light on plus i have no screen display
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
black 316
Rank: Apprentice
Rating: 62%, 2 votes
need help on my x- box 360 3 red ring
Was this helpful?
Yes
No
Solution #5
posted on Nov 09, 2009
Not Rated)
repairtech99
Rank: Guru  Microsoft Video Games  Expert
Rating: 91%, 149 votes
I Have come to the conclusion that continuous heat will
eventually warp the board , and short of installing a pelter cooler
device T.E.C. in the unit to remove the excess heat the only
other solution is a thermoplastic clamp that has lots of
little fingers to compress the G.P.U evenly from booth sides
at the right pinch points has yield the most durable repair,
after re-flowing the chip . I just had the tooling made for
the 3 molds needed for the three different G.P.U.s they should
be ready in two weeks
Rob
Was this helpful?
Yes
No
Solution #6
Not Rated)
david_n_jone
Rank: Apprentice  Video Games  Expert
Rating: 0%, 0 votes
ive been told to hold the "synch" and eject button down together which button is the synch on the wireless remote.thanks
Was this helpful?
Yes
No
Solution #7
posted on Aug 03, 2009
Not Rated)
Iceman843
Rating: 0%, 0 votes
Basically what you want 2 do is wrap your xbox in some covers and overheat it. do this for about 30 minutes. turn it off. turn it back on. and there you go. if this doesnt work txt me or call me 678-748-0250.
Was this helpful?
Yes
No
Solution #8
posted on Mar 14, 2009
Not Rated)
sober_nasty
Rating: 0%, 0 votes
my xbox wont start it flashes a red light after the green light doesnt rotate
Was this helpful?
Yes
No
Solution #9
posted on Jan 20, 2009
Not Rated)
paulnkuuj
Rating: 0%, 0 votes
i need help! my x-box 360 as a 3 red flashing...anybody with any idea? Please advice on what to do to solve this problem
Was this helpful?
Yes
No
Solution #10
posted on Jan 08, 2009
Not Rated)
dragon_rag27
Rank: Wiz  Video Games  Expert
Rating: 82%, 80 votes
you have whats called the red ring of death if it has warenty still return it and if not ...good luck xboxes arnt my area so... o and markfishwick if you have the same problem post it as that your answer was not a solution
Was this helpful?
Yes
No
Solution #11
Not Rated)
kingmathers
Rating: 0%, 0 votes
please help i have 3 red flashing lights
Was this helpful?
Yes
No
Solution #12
posted on Nov 09, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
just send it in to microsoft, it happens to almost everyones
Solution #13
posted on Nov 02, 2008
Not Rated)
Mepmep
Rank: Guide  Video Games  Expert
Rating: 78%, 5 votes
The best thing to do is to go to the Microsoft web(xbox360) get the toll free# let them know what is going on. They will repair it free of charge and the shipping is free. I had the same issue with my 360.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
During xbox 360 systemlink play in COD4, the little white speaker will flash on the screen when you... (More)
Answer
Madden 2010 freezes while playing and sometimes while loading
Answer
im running vista and media player 12,went to xboxpcsetup and it said it wont run on my media... (More)
Answer
I am trying to play a game that needs an update but half way through the update it stops and says... (More)
57 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 17, 2008
i have 3 flashing red lights on the rol and the power supply is green what do o do
2 red lights
1 red light
Comment by Guest, posted on Nov 16, 2008
1 red light
1 red lights
2 red lights
1 red light
Comment by Guest, posted on Nov 15, 2008
2 red lights
3 red lights
blank screen
2 red lights
Three red lights come on when i try to turn it on
Comment by Guest, posted on Nov 14, 2008
1 red light
2 red lights
2 red lights
1 red light on blinking
2 red lights
Comment by jjv_36, posted on Nov 14, 2008
I also have the same problem the three red rings
Comment by Guest, posted on Nov 13, 2008
2 red lights
freezing up too :(
Comment by dmoney452, posted on Nov 13, 2008
I can get online and play xbox live but after about 20 minutes or so my xbox freezes, And when I turn my 360 on the 3 red light start flashing
1 red light
1 red light
Comment by Guest, posted on Nov 12, 2008
2 red lights for me
Comment by antiescoto, posted on Nov 12, 2008
Yea i have three flashing lights on my xbox 360
3 red flasheing lights,
3 red for me
Comment by kingmathers, posted on Nov 11, 2008
the compuyer comes on green then after a couple of seconds it flashes red, and no picture.
Comment by Guest, posted on Nov 11, 2008
1 red light on
Comment by Guest, posted on Nov 10, 2008
3 red lights
2 red lights on
Comment by Guest, posted on Nov 09, 2008
3 red lights flashing
3 red light
1 red light flashing!
2 red lights flashing
Comment by frantsvog2, posted on Nov 08, 2008
three red lights flash when power button is pushed on 360 console.
Comment by sting0789, posted on Nov 08, 2008
xbox stopped working and had 3 flashing lights.
contacted microsoft who said it would be repaired free even though out of warranty (12 months).
Suspicious that when they get the xbox it won't be free of charge (unless i pay then xbox won't be sent back)
or there'll be a cost to send it
so would rather fix myself if simple and lasts a long time!
Comment by Guest, posted on Nov 08, 2008
its a white xbox360 amd has 3 red lights
2 red lights
Comment by Guest, posted on Nov 07, 2008
3 red lights on
1 red light
blank screen
Comment by Guest, posted on Nov 06, 2008
1 red light error
3 red light
3 red lights
2 red lights
Comment by Guest, posted on Nov 05, 2008
3 red lights
1 red light on
Comment by Guest, posted on Nov 04, 2008
2 red lights
2 red lights
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
