Question about Dell Inspiron 1000 Notebook
Inspiron 1000 - screen problem
Hi
My old inspiron 1000 has developed an odd fault. It just will not boot either on mains nor battery. I have taken it apart and found that if the LCD screen is disconnected from the motherboard it boots fine ( checked with external screen) As soon as the lcd panel is re-fitted it fails to boot again.
Any ideas how to repair?
  • 1 more comment
  • skullster Oct 24, 2008
    Thanks Helpfullguy I guess thats what I thought. Although before this happened the screen was working fine then a few times the screen came on then it powered off then just wouldn't come on. I'll remove all the cables and connectors and re-seat them then try again - otherwise its on e-bay for parts - shame as it has a new batter as well!
  • skullster Nov 02, 2008
    Thanks lobobs but the problem seems to bt if the LCD connector on the motherboard is plugged in. If its in iot will not even boot if its out and on external display all is well.
  • skullster Nov 03, 2008
    Hi All
    I have fixed the old girl! After stripping down the lcd panel it seemed that where the thick cable was inserted into the connector at the top of the back of the LCD panel that one side was not really in as far as the other. I pulled off the cable and re-inserted the connector then stuck back down the cable. I lso checked all other connectors. When I applied power it only started up! Oddly once I had put it back togeather it refused to boot but this time the num lock and scroll lock key remined lit and power still went to the processor. The fix for this was removing the DVD drive
    Then she booted again. So I re-inserted the drive ithout the lock screw and she still live. Now trying to install Ubuntu but the drive sounds alike a bag of nails. Just picked up another 1000 on e-bay for £50 (faulty) but is complete apart from RAM so Ill have spares to play wuith to hopefully keep her running a bit longer. Thanks everyone who helped.
    Problem Solver:
  • 4 Answers
I have had the same problem, but now i have solved it. there is a peice of aluminum tape on the ground boss that is extruding too far out over the pc board. this is located where the left lcd (screen) mouting is. when you move screen it makes contact to the pc board. that is why if you take out lcd mounting screws it may work ok. this tape is between top and bottom covers. I had mine all apart when I saw this. You may be able to see this if you take the shield off under the keyboard. if you can maybe you can trim it back so it won't touch pc board. Also you may have to replace on/off switch. i did because it was intermittent from been pushed so much. That requires complete disasemble.
lobobs
Posted on Nov 02, 2008
  • 35 Answers
Wow... That is a strange error. If, when the LCD is unplugged, it works, and when it's plugged in, it doesn't even power on, the only thing it could be is the LCD.
Without looking at it, it's hard to be 100%, but it sounds like there is a short somewhere in the LCD panel causing the issue. Unfortunately, unless you have a spare LCD lying around, it's probably not worth repairing (LCD's can cost between $70-$200 from eBay and other equivalents)
You can go through with a digital multimeter on all the connectors and see which one isn't correct but that's only easy if you took a 3 year digital circuits class in College like I did.
Sorry.
Posted on Oct 24, 2008
Inspiron 1000 doesn't save cmos settings
Hi
As you said that you haven't used the computer for long time then it could be the motherboard which has gone faulty not the HDD or DVD.
Try to use the new HDD with this old motherboard.
Or else you can seek help of Any Geek Squad or computer vendor.
In case if you have any more trouble do contact back in Fixya.
Thank you
Sep 05, 2012 | Dell Inspiron 1000 Notebook
My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
May 02, 2010 | Dell Inspiron 6000 Notebook
Dell inspiron password fault
Hi my inspiron 6400 cannot boot up after trying several time .I press switch on, then after 3 second it goes off again.Battery fully charge.
1)battery new
2)rep used mother board
3)rep touch pad
4)rep keyboard
I hope anyone that know this fault .Kindly help me with the issue.
Mar 08, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1000 will not boot up.
Greetings,
The symptoms you described are normally common motherboard failure signs.
Try removing the ram and hard drive from the computer and then try booting the computer.
Oct 28, 2008 | Dell Inspiron 1000 Notebook
Replacing a motherboard in a dell Inspiron 1000 laptop, and the screen not working
u need to reset the bios to factory defaults..this would fix your problem
Feb 06, 2008 | Dell Inspiron 1000 Notebook
DELL INSPIRON 1000
Try the following:
1. Try to boot the notebook with both battery and adaptor attached.
2. Try to boot with ONLY the battery.
3. Try to boot with ONLY the adapter.
If you can't boot with only the adapter, the adapter has died. If you can't boot with only the battery, the battery is dead.
But as stated above, make sure your battery is sufficiently charged.
In case of a dead battery or adapter, check whether the device is still under warranty. Contact HP if so.
Let me know what you found out.
Greetings,
DarkNeogen
Jan 24, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
193 people viewed this question
Alun Cox
