Question about John Deere Garden
John deere 5302 tractor wont come out of park
Tractor starts, can not get it out of park. tried rocking the tractor back and forth but no help. dont know what to do. cant get it to a shop cuase its stuck in the barn.
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
Where is the free wheel lever on john deere x724
I'm not familiar with that exact model but I do have friends with JD riders similar to yours.
If you are referring to the lever that releases the hydrostatic transmission so you can push it without starting the engine it will be on the back of the tractor on the big steel plate that faces the rear of the tractor. There is a rod you can pull outward to release the transmission. Some have a small loop for a finger hold, some do not. The ones I am familiar with, you need to pull the rod out, away from the tractor. That should release it. If not, rock the tractor back and forth a few times.
Sep 24, 2014 | John Deere Garden
Have to pull 600gator to start it
Push you stick to press it into nutrueal if that does not work wiglle back and forth on your seat while starting your tractor to move the wheels back and forth this may be a safty mechenisim desighned into your model
Apr 13, 2014 | John Deere 6300,6300l,6400,6400l Tractor...
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
John Deere 200 died while in reverse, can't shift into neutral so I can restart the engine.
Try having it rocked back and forth while trying to take it out of gear its worked for me a few times.
Jan 30, 2013 | Garden
John deere d170 hit rock and mower will not engage
well if you READ your owners manual its tell u how to reset it or fix it...
May 15, 2017 | John Deere Garden
The clutch on my john deer 970 tractor wont release. how do i get it unstuck.
under your rider there is a double pulley take off one of the belts the center part is suppost to go back and forth speay some carb cleaner or equivilent on the center shaft and manually work back and forth it may take a few times of spraying it gets stuck and wont releaseit has to move back and forth easily, i hope i helped you, thank you.
Dec 11, 2009 | Garden
Parking brake wont release on a 310e back hoe, replaced the parking brake switch and that was no help
Sounds like the whole stop brake system is seized up. Lot of wd40 and elbow grease should do it.Good luck.
Mar 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
51 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
