Question about Canon Office Equipment & Supplies
I don't know how to change the settings on my printer so that it will actually "print." When I press the energy saver button, it automatically goes to "copy". My printer is a Canon Super G3. What button should I press to make it print?
  • Pablo Csaky
    Pablo Csaky May 11, 2010
    Canon's Super G3 high-speed facsimile technology - Let me know exactly which is the model number of your printer to help you out better with your issue
    Genius:
  • 1,124 Answers
You will find all the info for your printer here:
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
If your printer is not listed there, use the search field to find it.
All the canon models are available there.
Posted on Oct 27, 2008
How do i turn off energy saver toshiba e studio 203d
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver butto
May 18, 2012 | Toshiba e-studio 203sd
How to ready toner not recognized
Hello
Please switch off the machine, while holding down0+8 buttons switch the machine on.
When machine starts and displays [ad] input 695 and press the start button.
Input 0 and press interupt and energy saver.
Input 971 and make sure that value is 3, if it is not input 3 and then press interupt then energy saver buttons.
Switch off the machine, wait awhile then switch the machine on.
The problem should be sorted out,
Regards
Apr 16, 2011 | Toshiba E-Studio167 Copier
When we are not using the printer for a long time, roughly 1 hour, the CPU Displays "Printer in Energy Saver Mode". how to activate as a Printable mode, the way we are doing is just restart the...
Dear vasanth, stand in front of the machine look at the right side, there will be a light green button
(small) if you press it the printer goes to energy save mode, again you press it, it comes to printable mode, no need to restart. if doubt persist call 9841315555(chennai)
Jan 17, 2011 | Xerox DocuColor 12 Printer
Printer goes into "power saver" mode and won't
Normally this printers has this "power save mode" as you call as defaults.I don,t find any other specification to set in other option, and normally takes few seconds after a command print job..But if you want a more fast response when want to print just press the On/Off button.
Dec 17, 2010 | HP Officejet 6500 Wireless All-in-One...
Why is light blinking on on-off button?
The blinking light indicates that the printer is on power saver mode. The Power Saver Mode saves energy by lowering power consumption during extended periods of inactivity. However, if you try to print from your computer when the printer is on power saver mode, the printer should automatically wake up and prints the job. You can also manually wake it up by just pressing and releasing the power button. Thanks.
Nov 19, 2010 | Lexmark X2470 All-In-One InkJet Printer
Can you change the energy saver adjustment
yep!
you can change it. actually it is on user's settings
it is located under general settings key operator mode.
just scroll down for energy saving
mostly the default value is sleep mode. after you press the sleep mode, the it will ask you for the sleep time you want. just press a number ( each number corresponds to number of minute)
that's it
Apr 02, 2010 | Panasonic Office Equipment & Supplies
Do not know how to use the energy saver feature
i have a problem for minolta di351 by code c009 pls help me
Feb 21, 2009 | Toshiba e-Studio 350 Copier
How to turn off the cleaning page feature in Xerox Phaser 8500
Actually what is happening is your machine is going into the power save mode and staying there for a long time.
What happens then is you get a full warmup. When the machine warms up, it will turn on the compressor and drain the resivour because Xerox wants a "fresh": supply of ink in the print head.
Its excruciatingly expensive and wasteful.
Here is something that can help. I am not sure you can completely disable the energy save mode. Thanks Al Gore...
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen
Dec 17, 2008 | Xerox Phaser 8500/DN Printer
My phaser 8560 won't say on, so it prints out the cleaner page and info pages daily after the very long warm up session. How can I keep it running so I don't burn through this very expensive ink.
Here you go.
To enable or disable the Power Saver (Energy Star) mode:
NOTE: The printer will only have the Power Saver menu selection if the printer was sold as an Energy Star machine.The Power Saver mode can only be enabled or disabled from the Control Panel.
  3. Press the [Up] or [Down] arrow button to select [Power Saver], and then press the [OK] button.
  4. Press the [OK] button until the required option is displayed; either 'On' or 'Off'.
  5. Press the [Down] arrow button to select [Exit], and then press the [OK] button to return to the main screen.
Oct 28, 2008 | Xerox Office Equipment & Supplies
Energy saver mode
Yes you can change the power save mode. I don’t remember from where you can change it. but its easy for you if you get the all operation manual list form the printer, get the setting page from printer by pressing the menu from your printer then you will get all commands so then you can change all settings of your printer.
Nov 30, 2007 | Konica Minolta PP9100 N Economical...
49 people viewed this question
old marine
old marine
