Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer lsq9549lw3 - specification
Want to know how big this washer is
2 Suggested Answers
  • 1417 Answers
SOURCE: whirlpool lsq9549lw3 washing machine wont spin
Hello.
If your washer is indeed a WFL2066, than the not spinning is directly relatedto the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drainpump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breakerat the home service panel...safety first**
1) Open the small square plastic door at the right bottom of thewasher.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works a swell.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check for leaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting our site please take a moment to rate the infoprovided for you here.
Thanks.
Posted on Sep 30, 2011
We have a lsr7233 bwi or dwi top loader washer and the basket is getting big holes in it betty
Here is a link to the basket replacement. The price of the basket replacement may be a little to much cost wise for you and might be better to get a new washer. Let me know if you want to replace the basket and I could walk you thru the replacement process.
Jan 10, 2011 | Whirlpool LSR7333 Top Load Washer
Washer just stopped working and smells like something just burned
take the belt off and let me know if you still smell burning
next with the belt off turn each pulley under the washer there are 3
the big one in the middle...in one direction makes the unit agetate in the other releases the break and the basket turns.. does this happen?
next the pulley to the right is your pump how is that does it sound strange when you turn it?
next spin your motor pulley does it spin freely?
let me know what you find
Feb 07, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My washer will not spin or drain
most washers have a timer relay if it has started to go out this is one of the problems that can happen so check thie timer relay it is the big nob you turn to start your washer. Just so you know sometimes the relay cost more then a new washer but it's worth cecking out.
Feb 18, 2009 | Whirlpool Inglis IP4400 Washer
Dishwasher
there are 2 screws holding the wacher to the counte top. (right on top of the washer latch, upside down).
if you can't get the washer out. then you can fix the problem. I gather you know what the problem is.
Aug 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Rear driveshaft assembly
what do you need to know about it? they have a bearing behind a heat shield and also they have like a big rober washer called
i can't remeber the name but those washers have to be nice not cracked or to dry if you see cracks or worn out it is time to replace it.
May 28, 2008 | 2001 BMW 325
MAH4000 washer
VERY BIG JOB!!
This job requires replacing outer tub. If you want, I can spell out whats involved. Expect at least a couple hours and a pretty large parts bill. Let me know!!
Nov 15, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Automati Washer Spin Cycle
never heard the vinegar in the rince water thing but who knows! do you know if the washer drum is working in the wash cycle? as you know it should tumble in both directions. if you ca check that it would be a big help to know if the motor is working. it could be something as simple as the belt broke. so get back to me with the answer and we can go from there. thanks
Aug 04, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
