Question about EuroTech EDW242C Dishwasher
E5 error on eurotech dishwasher
The dishwasher will run, and then stop during different parts of a cycle.
3 Suggested Answers
  • 6 Answers
SOURCE: Error messages on a EuroTech EDW154E dishwasher??
Eurotech Dishwashers are notorious for the E1 and E4 faults. The problem is with the solenoid they use for filling the dishwasher. The problem is something called the "Venturi Effect". The Venturi effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity. while its pressure must decrease due to conservation of energy. The gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. I know, a lot of big words. To put it simply, the orifice within the solenoid is smaller than the inlets and outlets. Even more simply put: Not enough water is getting into the dishwasher. It's a design flaw and I'm not certain there are many ways around it. Just make certain that you have a good water feed to the dishwasher (no kinks, valve on completley etc.). One thing you may try is reducing the feed pressure (i.e. slightly turn down the water valve supply to the dishwasher). Doing so may diminish the venturi effect by equalizing inlet pressure. It's worth a try.
Posted on Feb 07, 2009
heatman101
  • 43501 Answers
SOURCE: error message erro1 on eurotech dishwasher
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 30, 2010
What does the error code ER5 for a EDW154E Eurotech D/W mean?
e5 error is drain error. need to check all drain related items.
drain pump, drain hose, and of course garbage disposal knock out.
Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
Error code e5
Oct 01, 2017 | EuroTech Dishwashers
What is error 1 message mean?
What is error 1 When you start a dishwashing cycle, the dishwasher fills and then shows the error message when it should go into the wash mode
Dec 09, 2009 | EuroTech 24 in. EDW174E Built-in...
E5 error - need to know where drain hoses are
tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
May 12, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher
Could also be a water temp problem. If the water isn't hot enough the dishwasher will run longer as it has to heat the water. This could be your water heater turned down too low or the heating element in the dishwasher isn't working properly.
May 14, 2008 | EuroTech 24 in. EDW154E Built-in...
Dec 30, 2007 | EuroTech 24 in. EDW154E Built-in...
Error codes
Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
May 26, 2007 | EuroTech 24 in. EDW194E Built-in...
Dishwashers Logo
15 people viewed this question
Top EuroTech Dishwashers Experts
Tony Houde
Tony Houde
Tom Chichester
Dave Glabb
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
