Question about Vizio m420nv 42 in. LCD HDTV
Vizio m420nv mirror image
When i turn on my tv, the Vizio logo appears backward
phongnv
  • 56 Answers
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Posted on Feb 19, 2009
SOURCE: Vizio TV turns off as soon as you turn on the TV
Transformer is bad in the ac adapater.
Posted on Mar 27, 2009
  • 8457 Answers
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Posted on Jan 08, 2010
  • 13 Answers
SOURCE: when i turn the tv on shows the vizio logo only
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
  • 13 Answers
SOURCE: Vizio TV 2006 vx32Lhdtv doesnt work.
Testimonial: "If all things are equal than the solution is at hand. I thamk you!"
Vizio m420nv tv wont turn on but logo lights up
Test the PWR-ON terminal on the power supply and see if you have about 3.5 volts there
May 03, 2018 | Vizio Televison & Video
VIZIO M3D470KD TV TURNS ON, HAVE BACK LIGHT, V LOGO APPEARS ON SCREEN THE FADES AWAY.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Sep 30, 2016 | Vizio M3D470KD 47 inch Class Theater 3D...
Backwards/inverted picture vizio m420nv
this would require the service menu & I highly recommend a technician do this as if you are able to find the service code you can get into a position that the TV does not work at all.
Apr 21, 2014 | Vizio Televison & Video
M420NV
Check and replace back-light inverter board. Check the input supply voltage to back-light inverter board. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 23, 2013 | Vizio Televison & Video
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
E390vl turns off after vizio logo
The main board is bad. You can get the replacement main board from www.tvrepairworld.com
Jan 09, 2013 | Vizio 39" E390VL 1080p LCD HDTV
Vizio M420NV Wont turn on
I have a suggestion if you have and are using a box of some kind with this set, remove set and box from power for awhile and then power both back, sometimes a box can trigger this type of event, hope it helps and it cannot hurt to try.
Dec 11, 2012 | Vizio m420nv 42 in. LCD HDTV
Vizio m420nv without a remote
Contact Vizio for part number by model number or Google the model to locate an original (universals are a waste of time and money and often are missing key features needed).
Mar 31, 2012 | Vizio m420nv 42 in. LCD HDTV
Mirror image - can't fix
It likely has a problem that has affected the microprocessor in some way which might be explained if you had a power outage?
I would suggest if you have not done so to unplug it for a while and turn it back on after a hour.
Also call customer service at Vizio and inquire if this is a known problem and if there is a possible software upgrade to correct and restore the set to original shape.
It can be a pain to call and wait on the phone and is hit or miss as to seeing if the person who tries to help knows what they are doing or not.
If they snap an answer "you need to take it to a shop" persist and try to talk to a technician.
Mar 22, 2012 | Vizio m420nv 42 in. LCD HDTV
Open Questions:
See all Vizio m420nv 42 in. LCD HDTV Questions
Vizio m420nv 42 in. LCD HDTV Logo
317 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
