Question about Asko T711 Electric Dryer
Asko Dryer model T-701
My dryer just just stopped working because the tensioner arm broke off the moter housing. I'm not sure how it was originally attached (screw, pressed into the housing, etc.) and don't know how to replace - short of replacing the entire moter. Please let me know if you have encountered this problem before and how it can be fixed - preferably by me, since the machine is long out of warranty.
Thanks
Roy
Hello
i have T711 model ASKO Direr i could not find the belt NO.from the manual.how can i order the same..??
Posted on Jun 29, 2011
    Sergeant:
  • 351 Answers
You need to replace the motor you can replace the rear half of the motor but you can only buy a complete motor.this isnt a common problem but i have had it before.it broke because you need to grease the pin every 5 years or so.
Posted on Oct 30, 2008
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor · Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
Belt broke and there is a small plastic part melted lying in bottom of dryer housing that looks like maybe some kind of a guide for the belt+a shoe type device lying in the bottom, looks like the belt goes...
sounds like the plastic take-up pulley on the motor which is spring loaded to keep the drum belt tight. You will have to replace the tensioner which should, depending on the model, include a new plastic pulley.
Oct 16, 2009 | Whirlpool LGR3624JQ Gas Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Asko dryer: room temp air, is not heating
first try the reset button .. a black rubber button at the back panel about middle...
Hope it helps if NOT let me know more about your problem... and I will help
Jul 02, 2009 | Asko TL751 Electric Dryer
Asko t702c stops working after about 5 minutes
If you continue to try to run the dryer after the automatic shut off kicks-in it will shut the cycle down with no flashing lights after the dryer reaches a critical and dangerous temperature. If the dryer is skipping immediately to this step without any flashing lights then call an Asko certified repairman as something may be wrong with the machine. If you have not tried cleaning the condensor, please do this as well. Remove the bottom housing of the dyer, move the two red handle to the right, and pull out the condensor unit. Wash it under warm/hot water using a bathtub or shower and you will see lint and dust come out by the heapful. Replace the condensor unit, wait about 30-45 minutes, and then try restarting your dry cycle.
Kevin C., Asko USA.
Jun 07, 2009 | Asko Dryers
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer not getting hot
what is the model number for asko t 701
Aug 17, 2008 | Asko T701 Electric Dryer
Noise
remove the drum and check the front rollers,and the jockey pulley/belt for wear.also grease the jockey pin,you need to know how to remove the back panels on these asko dryers so you may want to ring asko to do it.remove all outer screws, centre nut and three screws left side about 3 inches up from base.hope this helps.
Mar 16, 2008 | Asko T701 Electric Dryer
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Dec 24, 2007 | Asko T700 Electric Commercial Dryer
How to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Nov 05, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Asko T711 Electric Dryer Logo
151 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
