Question about Microwave Ovens
Sharp 1000 Watt Light Duty Commercial Microwave, R-21JV. Problem: Unit will not operate. Not getting any power but external circuit breaker OK. Unit is less than 2 yeaqrs old.
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp Microwave problem.
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp Microwave Model R-1830: No power
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open oven thermal cutout (TCO) on the top of the oven cavity / body or an open thermal fuse on or above the magnetron.
These should read closed (virtually zero) on a continuity check.
If it went dead or when you plugged it in or opened or closed the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site but the best place to order Sharp parts is Tritronics.
Posted on Oct 13, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
  • 211 Answers
SOURCE: microwave / Frigidare PLMV
What size breaker is protecting the circuit? Per the National Electrical Code, a microwave and a washing machine should each have their own dedicated circuit (and own breaker) rated at 20 amps. Also, if the breaker is old and has tripped many times due to continuous overloading, it may be weakened and could be tripping at a lower amperage than what it is rated. I would try the following:
1. If possible, test the microwave on another circuit and see if it trips that breaker. If possible, use a 20 amp circuit for the test.
2. If you're comfortable with working in an electrical panel safely, place a clamp on ammeter on the hot wire of the affected circuit in the panel and see how much current is being drawn when the microwave is on.
3. If you would rather stay out of the panel, get an inline ammeter/watt meter and plug the microwave into this. If the rating of the microwave is less than 15 amps (1800 watts), you may be able to use a device called a kill-a-watt at a local hardware store. This will show how much power is actually being used by a given appliance.
Posted on May 28, 2009
garing
  • 998 Answers
SOURCE: Sharp Carousel R-1470A Over the range microwave-
check fuse
Posted on Aug 12, 2009
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Our commercial amana microwave model number rcs 10 mpa 1000 watt is not heating/cooking food. The power, lights, fans , display and everything else works fine. I would like to fix this myself. What part...
can be many problems. a defetive magnetron. worn door switches and its bracket/levers. circuit board issues. oven cavity thermofuse. etc.. good luck.
Aug 03, 2011 | Amana RCS10MP Microwave Oven
Microwave has no power
Sounds like a power board malfunction. Repair technicians usually have a minimum "bench fee" probably $50 - $75 / hour but they should be able to fix it within that hour. You will also have to purchase the power board, probably around $100 so you're probably talking about $165.00 to have it repaired.
Good Luck
Oct 08, 2017 | Sharp KB-6015K 1000 Watts Convection /...
Need your insight and troubleshooting on problem w/ our microwave
This could be the breaker at the panel or the fuse inside the microwave.I would check the panel box for any tripped breakers and then the fuse inside the unit.
May 03, 2009 | Sharp R-1502 Microwave Oven
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Feb 12, 2009 | Sharp KB-6015K 1000 Watts Convection /...
Using too much electicity!
We have been checking our electricity units
Not sure how you are checking but your microwave would blow fuses or trip a breaker if it was drawing more than it did since they are only ~ 50% efficient (any of them) which means a 1000 watt unit is pushing the limits of normal household circuits anyhow.
I bought two Kill-A-Watt power monitors for our two households and we are all happy with their convenience and the ability to quickly check anything that plugs into a standard US outlet and they are plenty accurate enough for us heathens.
Take a look:
I didn't price-shop too much but ours came to only $14 each plus shipping of $10 US.
Dec 18, 2008 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
