Question about Ovens
How do I fit a replacement thermostat to Electrolux EOD 983 top oven?
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: electrolux fan oven. Have replaced the
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Sep 15, 2009
Testimonial: "Ok will try that, but is the elemant at the top of the oven not the same one that heats up the grill? If so the grill heats up fine. "
  • 174 Answers
SOURCE: OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Posted on Jul 23, 2010
mnwarfield10
  • 452 Answers
SOURCE: Model EOD 43102. The Fan
see if u have a limiter ...its like a bullet (covere in white cover ) it will have a burn mark on end if you have one. u need to take the top cover off also when you are there take the control switch off see if its melted were the pins move up and down ... (contacters).... other wise take therear cover off inside main oven and inspect the fan element.
Posted on Feb 27, 2011
Electrolux EOD 985 bottom oven over heats burnng food
thats because the heat sensor isnt working properly need to replace
Apr 25, 2012 | Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
Model EOD 43102. The Fan oven will not reach required temperature. I have just had the thermostat replaced. Still the same. 3 years old. godden1@ntlworld.com
Feb 27, 2011 | Electrolux E30EW85GPS Oven
Fan oven is getting much hotter than what the thermostat indicates. Is it the thermostat or the switch
The thermostat controls the oven temp, therefore it is logical to assume that the thermostat is not sensing the temperature properly, so I would fit a new one.
Nov 27, 2010 | Electrolux EOD5310 Electric Double Oven
OVEN OVERHEATING
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
Heard a pop/bang and now no heat
Sounds like the oven element has blown.
To fit a new one, remove cover at rear of inner oven compartment, there you will see the round fan element.
Apr 06, 2010 | Electrolux EOD5330 Ultrafan Electric...
My electrolux eod33002 bottom oven does not heat up but light and fan work. The top oven works OK
If youhave a ELECTROLUX electric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fan motor in theback of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from our websitethese can be tested with a electric meter.
To gain access to the ELECTROLUX element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if you look closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is opencircuit i.e. broken inside the element casing, either way it will needreplacing. Some elements will are fixed from inside the oven and some are heldin place by nuts from the rear of the machine.
2, If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
4, A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 04, 2010 | Electrolux Ovens
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Electrolux Oven EOB6630, similar to above
Hi, I've had a similar problem with my electrolux EOB4633. I've replaced the "thermal cut out unit" and it's working now. Basically this unit switches on the outer casing fan ( on top in my oven ) to keep the casing from overheating. When the thermal cut out doesn't work it fails to switch on the fan and the casing overheats, the oven then cuts out completely until it has cooled down and the cycle starts again.
The bit to be replaced ( part no 8996619267611 ) is located on top of the oven, under the outer cover, just behind the timer & selector switch. It's a small ( 1inch long ) silicon sleeve with 4 wires coming out of it, just unplug the wires and replace it with the new one ( unplug/disconnect the power to the oven, or switch of the power at the mains switch first ), then remove the oven outer top cover ( all you need is a screwdriver ). You'll see the offending unit, probably tie wrapped to one of the wire bundles, quite easily - mine was blackened and charred.
Jan 29, 2008 | Electrolux EOB6636X Ultrafan Electric...
Ovens Logo
95 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
