Question about Microsoft Xbox 360 Console
No Color Will someone please give me a solution to my problem. My xbox360 is not showing any color. Everything including games and dvds are black and white. The system works fine in every other area including xbox live, playing games and dvds, etc.
  • fixyaixya
    fixyaixya May 11, 2010
    what type of connection are you using between the tv and the xbox? have you tried to hook it up to another tv?
Check the color and display settings on the 360 as well as the tv
Posted on Oct 24, 2008
Why is there no color
If using component video out please make sure that all cables are firmly and securely connected to the player and the TV.
-Component = Green/Blue/Red cables or jacks.
If using the video out please make sure that the TV color settings are not set to grey or black and white.
If everything is connected properly I would recommend to connect the player to another TV to see if the same issue will occur. Also check the color settings on the DVD player under picture mode.
Ref: http://www.docs.sony.com/release/DVPSR200P_US_ES.pdf
Dec 18, 2012 | Sony DVP-SR200P DVD Player
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
TIVO output is black and white only.
To solve this problem, I powercycled my TIVO.
Sep 17, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
My xbox has color problems
Component, HDMI? May want to check cabling. Having the component cables plugged in incorrectly can create color problems.
Sep 03, 2009 | Microsoft Xbox 360 Console
Color won't print! Test shows continuity.
I stand corrected, but this sounds strange. The black cartrige on a 650c is a no40, the colors are No50. It is impossible to place a color cartrige in the black posotion. You must remove all your cartriges and wipe them off at the bottom with a very hot wet cloth (not boiling) Let them stand on the wet cloth for quite some time and then give them a good shake (dont be shy). Be VERY careful not to get ink on your clothes or nearby objects. Once you have done this wipe them down again with a dry lint free cloth or tissue paper and try again.
Dave
May 18, 2009 | HP DesignJet 750c plus InkJet Printer
My xbox360 does not show any color
if this has only just happened and everything was fine before then try another av lead, or if you have a connection at the front of your tele to plug the red yellow and white av leads into try this instead of a scart connector
Oct 24, 2008 | Microsoft Xbox 360 Console
Printing only black
How long ago did color print correctly? If it is more than two weeks your cartridge has dried out and must be replaced. A test page including all colors and black is included in lexmark and dell printer programs. It should be run every week minimum and daily in hot, dry environments.
qwester1
Aug 21, 2008 | Lexmark X5150 All-In-One InkJet Printer
Xbox360
try turning your adaptor on and off
May 16, 2008 | Microsoft Xbox 360 Core System Video Game...
No color
I had the same problem with a PS2 connected to a small Sanyo TV. To fix it, while the game was playing I pressed a button on the remote control adjacent to an icon that resembles a square with a black dot in the bottom right hand corner. On my remote the button is directly behind the TV/AV button. As you press the button, one press at a time, this takes you through the various video format options available, including PAL, NTSC, Auto etc. When you reach the correct format the colour will return to your game.
In my case, I suspect this button was accidentaly pressed instead of the TV/AV button.
I hope this helps someone else as the problem had driven me mad all day before I stumbled over the solution.
Bob
May 04, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Console Logo
194 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
