Canon mp 830 getting error 5000 - Office Equipment & Supplies
  • Anonymous May 04, 2009
    I just looked over at the MP830 and the copy light was blinking and the display read error 5000 error code
Canon site if the link does not work just go to canon.com -> support-> select Multifinction --> Inkjet --> Pixma MP830
Then type in - error code 5000 - (Leave off the " - "
Select #3 - ERROR LCD: Error code (5xxx through 9xxx) appears on the display -
1. Press ON/OFF switch to reset the multifunction device
2. Press Stop/Reset and ON/OFF to reset the printer
3. Removing paper jams MP800R / MP830 / MP530
4. The MP830 may require repair
5. Unlock the scanner lock switch (MP800R / MP830)
The links above detail each instruction. If they do not work here then got directly to the Canon Site.
Basically at one point there was a paper jam so clear it and then reset the machine.
Worked for me. Good luck to you :)
Posted on May 04, 2009
I have an Canon MP 830 with error 5200. What can I do to fix it myself?
The error 5200 is either print head overheated or the logic board is faulty.
If it overheated, there might be burn marks on it somewhere or some distortion due to excessive heat.
Nov 29, 2013 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP 830 I replace purge unit
You may need a new printhead now, or you may have left a foam packing block inside the new purge unit.
Oct 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
2.
3.
Removing paper jams
4.
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Sep 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp 830 on my fax activity report I
Yes,it means the fax did not go through,it will show OK on the report if it was succesfull
Jun 29, 2009 | Canon imageRunner C3100 Copier
Canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Nov 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
0 answersI lost power. My canon MP 830 will not turn on now that power has been restored.
Yikes... This is common with electronics for some darned reason.
The power adapter that comes with the printer may need to be replaced. If this does not fix the issue.. then the power outage has shocked the device and it needs to be replaced.
Oct 31, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5110 canon mp 830
Replacing the cartridges is the most common problem
Jul 21, 2008 | Canon Office Equipment & Supplies
905 people viewed this question
k24674
jasbo
jasbo
