Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
Honeywell 360a humidifier
I hear the water running all the time to the humidier. The humidifier turns on with the furnace and works correctly, until the furnace turns off, the water continues to run through the humidifier. Shouldn't the water turn off when the humidifier turns off?
  • logoagogo Oct 31, 2008
    The water to my Honeywell Enviracaire flows constantly. Do I need to change the solenoid? I don't want to buy one as a test, but I can think of no other solution. My system is simple; there is no kind of humidity sensor that I can see. It just runs as long as the furnace runs, with a dial to turn it up to taste.
  • jettro23 Jan 27, 2009
    exact same problem only with an he260
  • 70 Answers
Yes water should turn off solinoid is bad
Posted on Oct 04, 2009
Honeywell humidifier short cycles
It's not uncommon for duct work in an older home to Bang as the furnace cycles due to age. The humidifier banging while turning on and of is mostlikely the solenoid valve; if the solenoid is bad it is actually to your benefit to replace the entire humidifier as the solenoids are very expensive, 50%+ of a new humidifier. Plus you get the 5 year parts warranty on the new unit instead of just one year on the solenoid. If you don't want to replace the entire unit you can replace the Humidistat, and that should fix the on/off cycling, however a new humidistat is included with a new unit, which again is more cost effective. They are easy enough to replace as a do it yourselfer, especially when replacing an existing unit. I hope this helps you.
Dec 29, 2012 | Honeywell HE360A1027 Whole House...
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
I installed a honeywell 360a flow thru humidifier, and a new transformer. I have power thru the wires to the fan cover. Also the humditstat clicks when turned on. The fan does not work and the solenoid...
Posting a diagram of how you wired the installation will help the both of us figure out what the problem is. You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Jan 11, 2011 | Honeywell HE360A1027 Whole House...
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from
Feb 05, 2010 | Aprilaire 700 Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
My honeywell humidifier attachment on my furnace will not start after the summer with water running to it.I have the humidity cranked up, but the filter is still bone dry.
Humidifiers usually are wired up to ONLY come on when the Heat is on and the fan running....anyother time you check it it will not be powered or wet...turn your heat on , wait till the fan comes on...then turn up your humidistat you should hear a click if its a flow through type and water should start flowing from the top...or if its tyhe drum style with the should see it then turning...if it doesnt turn the pad/spindle may not be installed properly...if only fits one way
Oct 24, 2009 | Honeywell Power Humidifier: Furnace...
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Honeywell furnace humidifier thermostat & other
sounds like to me you have a condensation pump attached to your hvac system. this can be used to pump water produced during the cooling of your house when in the a/c mode. if you have a typical bypass humidifier, you will have excess water running past the water panel and it must be sent to a drain of some kind. I would imagine the pump is being used to get your bypass water to the drain. another scenario may be that you have a 90% condensing furnace. if your exhaust pipe for the furnace is made out of pcv pipe, it is a condensing gas furnace. it will produce water when it is running. the water if from the combustion gases being condensed in the secondary heat exchanger. this is normal. some condensing gas furnaces will draw combustion air from inside the house and some will have a second pvc pipe that is used to pulll combustion air from the outside of the house. either way, it is not dehumidifying your house. the humidifier should be able to keep up if it is runnng properly. you should have water running out the bottom drain of the humidifier any time the fan on your furnace is running and the humidistat is calling for humidity. if this is not happening, it is not wired properly.
Jan 16, 2009 | Honeywell Power Humidifier: Furnace...
I just hooked up a honneywell whole house humidifer in my 1000 sq ft home. (last week) . i now see that the humidy has been at normal living condition. my problem now is i see i sttill go thru 15-20 gals...
Thanks for your question,
Well thats the big problem with bypass Humidifiers, they use alot of water, is yours running all the time, even when the furnace is shut down ? if it is, its wired in wrong, if not then there is not much of a solution for ya, is the humidity level in the home comfortable to where you can actually turn the house t-stat down ? if not you may want to incress the amount of humidity to be able to turn your house t-stat down, you should be feeling about 3 to 7 degrees warmer with the right amount of humidity, sorry I couldnt be more help, but thats the nature of that unit, just a little FYI, if you ever decide to try something different, may cost a bit more, try a steam humidifier, alot less water usage, its filtered, and pretty reliable too, thanks again for your question, hope atleast part of this helped !
Jan 05, 2009 | Honeywell HE220A1019 Whole House...
I have the HE265B By-Pass Flow-Through Hunidifiers installed in the summer, but it never on, until this fall, I tried to turn, but no water flow through. How can I test it? The contractor is NOT...
first break or loosen the water line connection at the humidifier and if you get water then you know it is something else. While the heat is running and main blower is also running, turn the humidistat from low to high; if you hear a click in the solenoid valve (where you checked the water) then you know it has power and the humidistat works. anything deyond that call a good contractor.
Nov 21, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
627 people viewed this question
Top Honeywell Humidifiers Experts
Simon Benzekri
Level 1 Expert
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
