Question about Photography
I need a shoe,lever,screw, & spring for a Craftsman Mod 469.84044. Sears no longer has the parts available. Who does or, who makes the Sears tripods to find alternative?
We just got a sears 469.84044 Tripod. We cannot figure out how to put the handle down for packing? any help? nfass@earthlink.net thanks
Posted on Oct 30, 2013
SOURCE: attaching camera to tripod
you need to find the "quick release plate" for that tripod
Posted on Nov 29, 2007
jessee007
  • 310 Answers
SOURCE: Kalimar Pro V-40 Tripod
If you have lost the screw no problem. Take the camera with you and go to you r local hardware store and fit it with a new bolt or srew.. It will be a standered size and thread. I loose this part all of the time
Posted on Jan 01, 2008
Sant139
Go to:
www.tripodquickrelease.com/Vivitar_Quick_Releases.htm
There is a list to select from you'll find it and it will cost $15.99
Good Luck,
Santa
Posted on Jan 31, 2008
SOURCE: Tripod plate leveler thumb screw
Try tripodquickrelease.com. They sell some repair parts for velbon tripods.
Posted on Feb 28, 2008
  • 24 Answers
SOURCE: Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Posted on Feb 10, 2009
How do I replace the spring in the lock off lever?
This is page 28 of the manualhttp://www.manualslib.com/manual/490926/Craftsman-113-235110.html?page=28#manual.
Nov 27, 2013 | Craftsman 10" Inch Miter Saw Sears Model...
Instructions and diagram,to remove and replace rear drum brakes
1984 Ford Tempo - Rear Drum brake drum/shoes
REMOVAL & INSTALLATION
See Figures below instructions
1. Raise and safely support the vehicle with jackstands.
2. Remove the wheel, tire, hub and finally, the drum assembly.
3. Using a spring removal tool, remove the horizontal securing spring at the top first of the assembly.
4. Pull the adjuster locking plate away from the shoes.
5. Remove the lower horizontal securing spring.
6. Unfasten one of the 2 shoe hold-down springs and remove the pin.
7. Remove the brake adjuster.
8. Remove the remaining hold down spring and clip.
9. Lift the brake shoes assembly off the backing plate and wheel cylinder assembly. Be careful not to bend adjusting lever during the removal process.
10. Remove the parking brake cable from the parking brake lever.
11. Remove the horseshoe retaining clip and spring washer and slide the lever off the parking brake lever pin on the trailing shoe.
To install:
12. Apply a light coating of high temperature grease at the points where the brake shoes contact the backing plate.
13. Apply a light coating of lubricant to the adjuster screw threads and the socket end of the adjusting screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back-off 1 / 2 turn.
14. Assemble the parking brake lever to the trailing shoe by installing the spring washer and a new horseshoe retaining clip. Crimp the clip until it retains the lever to the shoe securely.
15. Attach the parking brake cable to the parking brake lever.
16. Attach the lower retracting spring to the leading and trailing shoe assemblies and install to backing plate. It will be necessary to stretch the retracting spring as the shoes are installed downward over the anchor plate to inside of shoe retaining plate.
17. Install the adjuster screw assembly between the leading shoe slot and the slot in the trailing shoe and parking brake lever. The adjuster socket end slot must fit into the trailing shoe and parking brake lever.
The adjuster socket blade is marked R or L for the right or left brake assemblies. The R or L adjuster blade must be installed with the letter R or L in the upright position, facing the wheel cylinder, on the correct side to ensure that the deeper of the 2 slots in the adjuster sockets fits into the parking brake lever.
18. Assemble the adjuster lever in the groove located in the parking brake lever pin and into the slot of the adjuster socket that fits into the trailing shoe web.
19. Attach the upper retracting spring to the leading shoe slot. Using a suitable spring tool, stretch the other end of the spring into the notch on the adjuster lever. If the adjuster lever does not contact the star wheel after installing the spring, it is possible that the adjuster socket is installed incorrectly.
20. Inspect your work to make sure it is correct.
21. Install the hub/drum and wheel/tire assemblies and adjust the wheel bearings.
22. Lower the vehicle and check brake operation.
Fig.1 Exploded View of Rear Brakes - 1984 Ford Tempo
Fig 2. Remove the brake shoe upper retaining spring with a suitable removal tool.
Fig.3 Removed retaining spring - note spring direction.
Fig.4 Remove the adjuster lock plate. Note the direction of the tab.
Fig.5 Remove the lower retaining spring.
Fig.6 Remove the Hold Down Spring - note brake spring tool used.
Fig.7 remove the shoe adjuster. Note direction of the adjuster spline.
Fig.8 Remove the hand brake cable.
Fig.9 Remove the final brake shoe.
Fig.10 All removed parts in order and properly oriented for re-assembly.
Apr 17, 2011 | 1984 Ford Tempo
Replacing rear drum brakes. Need good diagram to indicate how to put it back together.
REMOVAL & INSTALLATION Light Duty Systems Fig. 1: Light duty brake system components 88489g21.gif
  1. Raise and support the vehicle and remove the wheel and brake drum from the wheel to be worked on. NOTE: If you have never replaced the brakes on a van before and you are not too familiar with the procedures involved, only dissemble and assemble one side at a time, leaving the other side intact as a reference during reassembly.
  2. Install a clamp over the ends of the wheel cylinder to prevent the pistons of the wheel cylinder from coming out, causing loss of fluid and much grief.
  3. Contract the brake shoes by pulling the self-adjusting lever away from the starwheel adjustment screw and turn the starwheel up and back until the pivot nut is drawn onto the starwheel as far as it will come.
  4. Pull the adjusting lever, cable and automatic adjuster spring down and toward the rear to unhook the pivot hook from the large hole in the secondary shoe web. Do not attempt to pry the pivot hook from the hole.
  5. Remove the automatic adjuster spring and the adjusting lever.
  6. Remove the secondary shoe-to-anchor spring with a brake tool. (Brake tools are very common implements and are available at auto parts stores). Remove the primary shoe-to-anchor spring and unhook the cable anchor. Remove the anchor pin plate. Fig. 2: Use an appropriate tool to disengage the retracting springs 88489g22.gif
  1. Raise and support the vehicle.
  2. Remove the wheel and drum. Fig. 4: Common heavy duty drum brake assembly 88489p45.jpg
    Fig. 5: Remove the brake drum from the rear axle 88489p31.jpg
    Fig. 6: Remove the parking brake lever retaining nut, located behind the backing plate 88489p32.jpg
  3. Fig. 7: Disconnect the adjusting cable from the anchor pin, cable guide and lever 88489p34.jpg
    Fig. 8: Slide the parking brake lever out from its mounting 88489p36.jpg
    Fig. 9: Disconnect the parking brake cable from the lever 88489p42.jpg
    Fig. 10: Use an appropriate tool to disconnect the return springs from their retaining holes 88489p37.jpg
    Fig. 11: Disengage the hold-down springs from the retaining clips on the backing plate 88489p41.jpg
    Fig. 12: Back off the adjusting screw and remove it from the brake assembly 88489p40.jpg
    Fig. 13: Spread the shoes apart and remove them from the backing plate 88489p39.jpg
Oct 09, 2010 | 1990 Ford Econoline
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Install the brake drum.
Thats it
Sep 10, 2010 | 1998 Ford Ranger SuperCab
Picture or directions for repairing rear drum brake
Brake Shoes Removal & Installation Duo-Servo Type To Remove:
  1. Raise the vehicle and support it safely.
  2. Remove the tire and wheel assembly.
  3. Remove the brake drums.
  4. Using a brake tool, remove the shoe return springs.
  5. Remove the shoe guide.
  6. Remove the hold-down springs and pins.
  7. Remove the actuator lever and pivot.
  8. Remove the lever return spring.
  9. Remove the actuator link, parking brake strut, spring retaining ring.
  10. Remove the parking brake lever and washer.
  11. Remove the shoe assemblies.
  12. Remove the adjuster screw and spring from the shoe assembly.
To Install:
  1. Use brake cleaning fluid to remove dirt from the brake drum. Check the drums for scoring, cracks and for out-of-round; service the drums as necessary.
  2. Check the wheel cylinders by carefully pulling the lower edges of the wheel cylinder boots away from the cylinders. If there is excessive leakage, the inside of the cylinder will drip fluid; repair or replace as necessary.
  3. Check the flange plate, which is located around the axle, for leakage of differential lubricant.
  4. Lightly lubricate the parking brake cable, parking brake lever where it enters the shoe and the backing plate-to-shoe contact points. Use high temperature, waterproof, grease or special brake lube.
  5. Install the parking brake lever into the secondary shoe with the attaching bolt, spring washer, lockwasher, and nut. It is important that the lever move freely before the shoe is attached. Move the assembly and check for proper action.
  6. Lubricate the adjusting screw and make sure it works freely.
  7. Connect the adjuster screw and spring to the bottom portion of both shoes. Ensure the spring does not interfere with the adjuster rotation when installed. The primary (smaller shoe pad area) to the front and secondary shoe (larger shoe pad area) to the rear of the vehicle.
  8. Install the shoe assembly. Ensuring the shoe webs are positioned correctly against the wheel cylinder.
  9. Install the parking brake cable.
  10. Secure the primary shoes with the hold-down pin and spring.
  11. Install the parking brake strut and the strut spring.
  12. Install the actuator lever and pivot, securing the assembly with the hold-down pin and spring. Install the actuator link and spring.
  13. Install the return springs.
  14. Check the operation of the self-adjusting mechanism by moving the actuating lever by hand.
  15. Adjust the brakes and install the drum.
  16. Adjust the parking brake.
  17. Install the tire and wheel assembly.
  18. Lower the vehicle.
Leading-Trailing Type To Remove:
  4. Raise the lever arm of the actuator until the upper end is clear of the slot in the adjuster screw.
  5. Slide the actuator off the adjuster pin. Disconnect the actuator spring from the shoe.
  6. Remove the hold-down spring assemblies and pins.
  7. Pull the bottom ends of the shoes apart and lift the lower return spring over the anchor plate. Allow the shoe ends to come together and remove the spring.
  8. Remove the shoe assembly, along with the upper return spring and the adjusting screw assembly.
  9. Remove the upper return spring and the adjusting screw assembly from the shoes.
  10. Remove the retaining ring, pin, spring washer, and parking brake lever.
Typical rear drum brake assembly (Leading/Trailing type) 93026g52.gif
To Install:
  1. Clean adjuster wheel and the backing plates with a suitable cleaner. Lubricate the backing plate contact points, levers and adjuster with a suitable lubricant.
  2. Assemble the parking lever, spring washer (concave side facing the brake lever), pin, and retaining ring onto the rearward shoe.
  3. Install the adjuster pin in the forward shoe with the pin projecting 0.276 in. (7mm) from the side of the shoe web where the adjuster actuator is installed.
  4. With the brake shoes resting on a flat surface (the shoe with the parking lever to the rear of the vehicle), install the upper return spring.
  5. Install the adjuster screw assembly with the spring clip facing the backing plate.
  6. Place the shoes in position on the backing plate. Do not place the lower shoe webs under the anchor plate.
  7. Install the lower return spring, spread the bottom of the shoes and position the shoe against the backing plate.
  8. Install the hold-down pins and spring assemblies.
  9. Install the adjuster actuator over the end of the adjuster pin so the top leg engages the notch in the adjuster screw.
  10. Install the actuator spring, being careful not to over-stretch it more than 3.27 in. (83mm).
  11. Install the parking brake cable to the lever.
  12. Adjust the parking brake if the shoes will not totally retract.
  13. Install the drum, tire and wheel assembly. Adjust the rear brakes and lower the vehicle.
Aug 17, 2010 | 1999 Chevrolet Suburban
1997 Ford contour rear brake shoe replacment help.
Brake shoe removel:
Depress and turn the retainers for the hold-down springs and pins to remove them from each shoe. Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Step 4 Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
  • Step 5 Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xgUqun
  • Step 3 Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xdByQ8
  • Step 2 Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xVyUAt
    Jul 17, 2010 | 1995 Ford Contour
    Need repair guide for rear brakes 1990 E350 Ford
    Ford Full-Size Vans 1989-1996 Repair Guide
    Brake Shoes - REMOVAL & INSTALLATION
    Light Duty Systems
    1. Install a clamp over the ends of the wheel cylinder to prevent the pistons of the wheel cylinder from coming out, causing loss of fluid and much grief.
    2. Contract the brake shoes by pulling the self-adjusting lever away from the starwheel adjustment screw and turn the starwheel up and back until the pivot nut is drawn onto the starwheel as far as it will come.
    3. Pull the adjusting lever, cable and automatic adjuster spring down and toward the rear to unhook the pivot hook from the large hole in the secondary shoe web. Do not attempt to pry the pivot hook from the hole.
    4. Remove the automatic adjuster spring and the adjusting lever.
    5. Remove the secondary shoe-to-anchor spring with a brake tool. (Brake tools are very common implements and are available at auto parts stores). Remove the primary shoe-to-anchor spring and unhook the cable anchor. Remove the anchor pin plate.
    1. Remove the cable guide from the secondary shoe.
    2. Remove the shoe hold-down springs, shoes, adjusting screw, pivot nut, and socket. Note the color of each hold-down spring for assembly. To remove the hold-down springs, reach behind the brake backing plate and place one finger on the end of one of the brake hold-down spring mounting pins. Using a pair of pliers, grasp the washer type retainer on top of the hold-down spring that corresponds to the pin which you are holding. Push down on the pliers and turn them 90° to align the slot in the washer with the head on the spring mounting pin. Remove the spring and washer retainer and repeat this operation on the hold down spring on the other shoe.
    3. Remove the parking brake link and spring. Disconnect the parking brake cable from the parking brake lever.
    4. After removing the rear brake secondary shoe, disassemble the parking brake lever from the shoe by removing the retaining clip and spring washer.
    To install:
    1. Assemble the parking brake lever to the secondary shoe and secure it with the spring washer and retaining clip.
    2. Apply a light coating of Lubriplate®, or equivalent, at the points where the brake shoes contact the backing plate.
    3. Position the brake shoes on the backing plate, and install the hold-down spring pins, springs, and spring washer type retainers. On the rear brake, install the parking brake link, spring and washer. Connect the parking brake cable to the parking brake lever.
    4. Install the anchor pin plate, and place the cable anchor over the anchor pin with the crimped side toward the backing plate.
    5. Install the primary shoe-to-anchor spring with the brake tool.
    1. Install the cable guide on the secondary shoe web with the flanged holes fitted into the hole in the secondary shoe web. Thread the cable around the cable guide groove.
    2. Install the secondary shoe-to-anchor (long) spring. Be sure that the cable end is not cocked or binding on the anchor pin when installed. All of the parts should be flat on the anchor pin. Remove the wheel cylinder piston clamp.
    3. Apply Lubriplate®, or equivalent, to the threads and the socket end of the adjusting starwheel screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back off 1 / 2 turn.
    Interchanging the brake shoe adjusting screw assemblies from one side of the vehicle to the other would cause the brake shoes to retract rather than expand each time the automatic adjusting mechanism is operated. To prevent this, the socket end of the adjusting screw is stamped with an "R" or an "L" for "RIGHT" or "LEFT". The adjusting pivot nuts can be distinguished by the number of lines machined around the body of the nut; one line indicates left-hand nut and two lines indicate a right-hand nut.
    1. Place the adjusting socket on the screw and install this assembly between the shoe ends with the adjusting screw nearest to the secondary shoe.
    2. Place the cable hook into the hole in the adjusting lever from the backing plate side. The adjusting levers are stamped with an R (right) or a L (left) to indicate their installation on the right or left-hand brake assembly.
    3. Position the hooked end of the adjuster spring in the primary shoe web and connect the loop end of the spring to the adjuster lever hole.
    4. Pull the adjuster lever, cable and automatic adjuster spring down toward the rear to engage the pivot hook in the large hole in the secondary shoe web.
    5. After installation, check the action of the adjuster by pulling the section of the cable guide and the adjusting lever toward the secondary shoe web far enough to lift the lever past a tooth on the adjusting screw starwheel. The lever should snap into position behind the next tooth, and release of the cable should cause the adjuster spring to return the lever to its original position. This return action of the lever will turn the adjusting screw starwheel one tooth. The lever should contact the adjusting screw starwheel one tooth above the centerline of the adjusting screw.
    If the automatic adjusting mechanism does not perform properly, check the following:
    1. Check the cable and fittings. The cable ends should fill or extend slightly beyond the crimped section of the fittings. If this is not the case, replace the cable.
    2. Check the cable guide for damage. The cable groove should be parallel to the shoe web, and the body of the guide should lie flat against the web. Replace the cable guide if this is not so.
    3. Check the pivot hook on the lever. The hook surfaces should be square with the body on the lever for proper pivoting. Repair or replace the hook as necessary.
    4. Make sure that the adjusting screw starwheel is properly seated in the notch in the shoe web.
    Heavy Duty Systems
    1. Remove the parking brake lever assembly retaining nut from behind the backing plate and remove the parking brake lever assembly.
    2. Remove the adjusting cable assembly from the anchor pin, cable guide and adjusting lever.
    3. Remove the brake shoe retracting springs.
    4. Remove the brake shoe hold-down spring from each shoe.
    5. Remove the brake shoes and adjusting screw assembly.
    6. Disassemble the adjusting screw assembly.
    7. Clean the ledge pads on the backing plate. Apply a light coat of Lubriplate®, or equivalent, to the ledge pads (where the brake shoes rub the backing plate).
    continue...
    Jan 15, 2010 | 2002 Ford E350
    1999 nissan quest rear brake shoes need changing
    help is here:
    http://autos.groups.yahoo.com/group/villagerquest/
    Drum Removal
    1. Remove the rear wheel and the tire assembly. Refer to Section 204-04 .
    1. Retract the brake shoes and loosen the brake adjuster screw.
    1. Remove the brake drum.
    May require big hammer to loosen drum from axle flange. Hit between the the lugs, not on them.
    #10 is access plug to back off adjusting wheel.
    Item Part Number Description 1 2261 Rear wheel cylinder 2 — Dust boot (part of 2128) 3 2197 Wheel cylinder piston (part of 2261) 4 — Cup (part of 2128) 5 2204 Wheel cylinder piston cup spring (part of 2128) 6 — Wheel cylinder housing (part of 2261) 7 — Brake shoe hold-down pin 8 — Access hole (part of 2212) 9 — Rear brake bleeder screw (part of 2261) 10 — Access hole plug 11 — Rear wheel cylinder bolt 12 2212 Rear brake backing plate 13 — Rear brake backing plate bolts 14 2N790 Parking brake lever clip 15 — Spring washer 16 — Secondary brake shoe and lining (part of 2200) 17 — Brake shoe hold-down spring (part of 2B514) 18 — Lower retracting spring (part of 2B514) 19 2A637 Parking brake lever 20 — Parking brake lever pin 21 2A177 Brake shoe adjusting lever 22 — Adjuster lever pin (part of 2A177) 23 — Primary brake shoe and lining (part of 2200) 24 — Upper retracting spring (part of 2B514) 25 2041 Brake adjuster screw
    Shoes Removal
    Take a picture and remember how each part goes and attaches
    1. Remove the brake drum, refer to Drum in this section.
    1. Remove the upper retracting spring.
    1. Remove the lower retracting spring.
    1. Remove the self-adjuster.
    1. Remove the hold-down springs.
    1. Remove the parking brake lever clip and the parking brake lever.
    Apr 17, 2009 | 1999 Nissan Quest
    I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
    Drum, Rear Brake System Standard Rear Brake
    Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
    Heavy Duty Rear Brake
    Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
    The rear drum brakes:
    • Have internal shoes that expand against the brake drum (1126).
    • Are a single-anchor type.
    • Are actuated by one rear wheel cylinder (2262).
    • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
    • Adjust rear brake shoes and linings (2200) automatically.
    • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
    When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
    The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
    Apr 04, 2009 | 1997 Ford F150 Regular Cab
    How to install rear brakeshoes
    If you are not thoroughly familiar with the procedures involved in brake replacement, only disassemble and assemble one side at a time, leaving the other wheel intact as a reference.
    1983-88 Vehicles
    See Figures 1, 2 and 3
    1. Raise and safely support the rear of the vehicle with jackstands.
    3. Remove the brake drum, as outlined earlier in this section.
    4. Place Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the brake cylinder.
    CAUTIONBe careful that the springs do not slip off the tool during removal, as they could cause personal injury.
    1. Remove the shoe-to-anchor springs, using Brake Shoe R and R Spring BT-11, or equivalent, then unhook the cable eye from the anchor pin.
    0900c1528006be0f.jpgFig. 1: Place the brake clamp tool over the ends of the wheel cylinder, then remove the shoe-to-anchor springs using the correct tool
    1. Remove the shoe guide (anchor pin) plate.
    2. Remove the shoe hold-down springs, shoes, adjusting screws, pivot nut, socket and automatic adjustment parts.
    3. Remove the parking brake link, spring and retainer. Disconnect the parking brake cable from the parking brake lever.
    4. After removing the secondary brake shoe, disassembly the parking brake lever from the shoe by removing the retaining clip and spring washer.
    0900c1528006be10.jpgFig. 2: View of the drum brake components-1983-88 9-inch brake shown 0900c1528006be11.jpgFig. 3: View of the drum brake components-1983-88 10-inch brake shownTo install:
    1. The brake cable must be connected to the secondary brake shoe before the shoe is installed on the backing plate. To do this, first transfer the parking brake lever from the old secondary shoe to the new one. This is accomplished by spreading the bottom of the horseshoe clip and disengaging the lever. Position the lever on the new secondary shoe and install the spring washer and the horseshoe clip. Close the bottom of the clip after installing it. Grasp the metal tip of the parking brake cable with a pair of pliers. Position a pair of side cutter pliers on the end of the cable coil spring, and using the plier as a fulcrum, pull the coil spring back with the side cutters. Position the cable in the parking brake lever.
    2. Apply a light coating of high temperature grease to the brake shoe contact points on the backing plate. Position the primary brake shoe on the front of the backing plate and install the hold-down spring and washer over the mounting pin. Install the secondary shoe on the rear of the backing plate.
    3. Install the parking brake link between the notch in the primary brake shoe and the notch in the parking brake lever.
    4. Install the automatic adjuster cable loop end on the anchor pin. Make sure the crimped side of the loop faces the backing plate.
    5. Install the return spring in the primary brake shoe and, using the tapered end of the brake spring service tool, slide the top of the spring onto the anchor pin.
    CAUTIONBe careful to make sure that the spring does not slip off the tool during installation, as it could cause injury.
    1. Install the automatic adjuster cable guide in the secondary brake shoe, making sure the flared hole in the cable guide is inside the hole in the brake shoe. Fit the cable into the groove in the top of the cable guide.
    2. Install the secondary shoe return spring through the hole in the cable guide and the brake shoe. Using the brake spring tool, slide the top of the spring onto the anchor pin.
    3. Clean the threads on the adjusting screw and apply a light coating of high temperature grease to the threads. Screw the adjuster closed, then open it 1/2 turn.
    4. Install the adjusting screw between the brake shoes with the star wheel nearest to the secondary shoe. Make sure the star wheel is in a position that is accessible from the adjusting slot in the backing plate.
    5. Install the short hooked end of the automatic adjuster spring in the proper hole in the primary brake shoe.
    6. Connect the hooked end of the automatic adjuster cable and the free end of the automatic adjuster spring in the slot in the top of the automatic adjuster lever.
    7. Pull the automatic adjuster lever (the lever will pull the cable and spring with it) downward and to the left and engage the pivot hook of the lever in the hole in the secondary brake shoe.
    8. Check the entire brake assembly to make sure that everything is installed properly. Make sure that the shoes engage the wheel cylinder properly and are flush on the anchor pin. Make sure that the automatic adjuster cable is flush on the anchor pin and in the slot on the back of the cable guide. Make sure that the adjusting lever rests on the adjusting screw star wheel. Pull upward on the adjusting cable until the adjusting lever is free of the star wheel, then release the cable. The adjusting lever should snap back into place on the adjusting screw star wheel and turn the wheel one tooth.
    9. Expand the brake adjusting screw until the brake drum will just fit over the brake shoes.
    10. Install the brake drum and wheel and tire assembly, then adjust the brakes.
    11. Carefully lower the vehicle.
    Dec 08, 2008 | 1987 Ford Thunderbird
    Photography Logo
    131 people viewed this question
    Top Photography Experts
    pontelemon
    pontelemon
    TC CAMERA REPAIR.Com...
    Are you a Photography Expert? Answer questions, earn points and help others
