Question about Maytag MHWE200XW Washer
I have a Maytag 2000 series washer and dryer, can I reverse the door swing?
SOURCE: Need to replace my Maytag the door is reverseable. Who makes those now?
The doors are reversabe they go from left hand open to right hand open. Just reverse the hinges, put the door fillers ( triangle shape go toward the front. Remove the plug put it in the other sidel. Now take the metal door strke and put it on the other side, Then take the filler from on side and put it on the other side. Takes 10 to 15 minutes to make the change.
No need to purchase another door!
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Posted on Jan 04, 2008
IFIXALL
  • 868 Answers
SOURCE: rotate the doors
You can reverse the doors and it is not very hard to do.If you need assistance I'll be happy to provide the help to do this.
Posted on May 14, 2008
  • 20 Answers
SOURCE: MFS9700S Maytag washer Can the door be reversed??
not on washer as far as i know . just dryers but just look in your book or call the store you got it at
Posted on Feb 21, 2009
barkencoa
  • 3463 Answers
SOURCE: how do you reverse swing on door
Ity is not normlly possible to reverse the door on automatic washers, as they are not configured for this.
Tthankyou.
Posted on Dec 19, 2009
Can I reverse the door swing on my Maytag Performa dryer>
http://www.maytag.com/-[PYE2300AYW]-1109316/PYE2300AYW/
Here is the link to the owners manual. This feature is not mentioned. Look at the molding in the metal case of the front of the dryer. See if there are identical moldings for the door and latch on both sides. If not, no. Only alternative is to get longer connection hoses and swap washer with dryer left to right.
Dec 24, 2014 | Maytag Dryers
Washer is noisy in spin cycle and won't spin water out
but clutch or loose worn belt, also check bad motor coupler
Aug 02, 2014 | Maytag Bravos MEDB400VQ 29" Electric Dryer...
How do I reverse the door swing?
Sorry but you can't - only the dryer allows you to reverse the door on these type of appliances...
Jun 15, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do you reverse swing on door
Tthankyou.
Dec 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
On these model you can only reverse the door swing on the dryer but not the washer.
Alternatively, you can switch places with the washer and dryer provided the washer fill and drain hoses are long enough and there is enough room without obstructing the dryer exhaust vent .
If you want to know how to reverse the door swing on the dryer, post your model number and I will try to assist you further.
Apr 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rotate the doors
Apr 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag dryer
Take off the door then remove the screws on the other side (where the door would be attached if it were reversed) You can now swing the front panel down from the top.
Dec 25, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MHWE200XW Washer Logo
1,082 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
