Question about Brother MFC-8220 Fax
Imagistics 2500 its instructing me to change the drum and I changed the drum and the toner, and it still says change drum
    Genius:
  • 2,120 Answers
With that model I believe you have to leave the toner door open and press start
Posted on Oct 25, 2008
Splotches in prints from our SX 1480
This is actually a Muratec machine. This is not an uncommon fault and it is ALWAYS a faulty toner cartridge. Although you say you have changed it, I doubt you have replaced it with a new one.
Change it I can guarantee it will cure it. I know as I am a muratec engineer!
Jan 27, 2014 | Pitney Bowes Compatible Imagistics / OCE...
Where is waste toner located in copier
In the past i have found the waste toner bottle is usually the same place as either the toner or the drum (mostly the drum) and will be a clear bottle. Possibly wide at the bottom and thinner at the top.
Hope this helps
Nov 07, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Is the "change drum soon" message instructing to
This indicator is for the drum unit, not the toner cartridge. The drum unit is the assermbly that the toner cartridge is inserted into when being replaced. The drum unit is replaced about every 18,000 pages so after about 5 to 10 toners have been replaced.
Here is a picture of the drum unit.
Oct 28, 2010 | Brother MFC 7420 All-In-One Laser Printer
I have a Minolta Di181 black and white copier. It started printing lines all through the paper and was a little dark. I bought another copy machine because this one is old. It is a imagistics zc25 this...
Well, you put your self into a pickel. With the Di181 you most likly neede a new drum and cln blade & a good cleaning. Now with the Imagistics, you may have the same problem, but you put Minolta toner into a Imagistics. Thats like putting oil into water and wonder why they don't mix? Now you need to replace the drum & blade & developer & toner and vaccum out all the toner and start off with all new. Good Luck
Jul 28, 2010 | Panasonic DP-8020E Black and White Copier
Imagistics SX 2100. When you change the drum what
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Jan 25, 2010 | Pitney Bowes Office Equipment & Supplies
Brother HL 2040 prints extremely light and seems to smudge? Just changed out the tone cartridge and no change.
I'm not sure if the drum is going out or not. How many toners have you used? The drum is rated at 12,000 pages and the toner is supposed to yeild 2500 pages, so 4 or 5 toners ought to finish the drum. Did you clean the area around the drum? I don't think you're supposed to touch it, but I've never had to touch my 7240 in 4 years, except to change the toner.
The good news is the toner will fit in more than one Brother machine and the printers are inexpensive. It almost makes buying a new machine more economical than a drum :-}
The HL printer is Manufacturer Discontinued, the new ones use a 360 series drum and toner, and the MFC's (7220 etc.) are about $200 vs. $116 for the drum. Hmmm.
Might be time to upgrade.
Carl
Jan 08, 2010 | Brother HL-2040 Laser Printer
Faxing problem Imagistics 2500
You're correct, it's the scanner. Finding out what exactly is wrong with it is a little more difficult. First check the easy thing, scan a sample paper 4 times, each time pushing it against a different one of the four corners, and see if the line goes away or changes when you change the location of the paper on the scanner. If that doesn't work, take off the glass plate and clean it and everything under it, then try again. If none of that helps, download the latest drivers.
Please rate, thanks!
Mar 13, 2009 | SMC Accessories Chembook 2500: Port...
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Imagistic 2500 Fax problem.
On top of the toner cartridge there may be a blue slider for cleaning the charge wire.
If not, you have a bad toner cartridge (drum cleaning blade)
Sep 16, 2008 | Brother MFC-8220 Fax
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother MFC-8220 Fax Logo
497 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
