Question about Norelco Health & Beauty
Where can i find replacement heads for a norelco 725rl shaver
    Guru:
  • 174 Answers
725rl replacement heads
norelco HQ56 replacement heads for philips norelco 725rl bades parts at http://www.menelectricrazor.com/norelco-725rl-replacement-heads/
Posted on Apr 22, 2012
  • 91 Answers
SOURCE: replacing batteries in a 6705x norelco shaver
To open up your shaver, remove the lotion cover and remove all 5 screws with a small flat head screwdriver. They have a star head, but also a flat notch. Since they shaver is water tight, the first time you open it up it will be difficult, but if you pry off with your screwdriver it should pop off.
Towards the head of the shaver the batteries are soldered to the circuit board. Pull the tail end of the batteries out of the plastic holder and cut them at the top end as close to the batteries as you can, or CAREFULLY bend it back and forth to snap the metal. Dispose of the batteries responsibly as you would any batteries.
Hope it helps you.
Posted on Jan 07, 2009
SOURCE: How to replace batteries in Norelco 6826 XL
Amazon has a number of reviews that tell how to do this. See
http://www.amazon.com/Shaver-Battery-Norelco-models-others/product-reviews/B000FP63M4/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Posted on Mar 25, 2009
  • 3 Answers
SOURCE: Replacing Heads for 8140XL Norelco shaver
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
brector3
  • 1624 Answers
SOURCE: How to lubricate Norelco 3405 shaver?
The sewing machine oil should work fine.
This model has 4 screws on the back. You must push up the trimmer to see two of those but the other two are in plain view. Remove screws with a flat jewelers screwdriver or you can purchase a special removal tool from shaveroutlet.com here:
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Once the back cover is removed, you will be able to see the motor. It is attached to the gear housing by two metal clips. Remove the clips and you can lift the motor out. Apply a couple of drops of your oil to the pinion gear on the 'front' of the moto and a drop to the small indentation on the back of the motor.
If you still have noise. you will need to lubricate the gears. Temove the gear housing by removing the 2 screws that are on either side of the motor. The gear housing will then come off. The front and back of the housing are held together by plastic snaps on the three corners. Gently pry them apart to seperate and reveal the gears inside. Lift the gears out and apply a light form of grease to where the gears fit onto the back of the gear housing. Vaseline should work well if you have nothing else.
Reassemble in reverse order and it should run very quiet when you're done
Posted on Jan 26, 2010
brector3
  • 1624 Answers
SOURCE: where can i find replacement heads for a norelco
The type of heads you need have been discontinued by Norelco for several years. It would be virtually impossible to fing a new set made by Norelco.
There is an aftermarket version available. You will find these at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-1912-3-type-heads-also-fits-remington-and-more.html
Posted on Jan 29, 2010
Is HQ9 compatiable with HQ55?
No, philips norelco HQ56 replacement heads compatiable with HQ55
philips norelco HQ56 for norelco 100db, 110db, 1323, 2005c, 200sc, 300sx, 3405lc, 3601x, 3604x, 3605x, 3801xl, 3805xl, 3865xl, 400dx, 410db, 4401lc, 4402lc, 4403lc, 4404lc, 4406lc, 4413lc, 4414lc, 4417lc, 4601x, 4602x, 4603x, 4604x, 4605x, 4606x, 4607x, 4608x, 4625,x 4805xl, 4807xl, 4816xl, 4816xld, 4817xl, 4817xld, 4821xl, 4825xl, 4825xld, 482xl, 4845xl, 484xl, 4852xl, 4853xl, 4861xl, 4865xl, 486xl, 4885xl, 500rl, 501rl, 505rl, 5426lc, 5625x, 5812xl, 600rx, 605rx, 6423lc, 6424lc, 6613x, 6614x, 6615x, 6616x, 6617x, 6618x, 665rx, 6843xl, 6844xl, 6853xl, 6854xl, 6856l, 6856xl, 6863xl, 6940lc, 6945xl, 700rl, 705rl, 710rl, 715rl, 720rl, 725rl, 750rl, 800rx, 805rx, 815rx, 825rx, 835rx, 850rx, 875rx, 885rx, 885rxac, 895rx, 900rx, 905rx, 915rx, 935rx, 945rx, 950rx, 955rx, 965rx, 968rx, 975rx, 985rx, hp1318, hp1319, hp1327, hp1327d, hp1328, hp1328e, hp1328s, hp1337, hp1337c, hp1601, hp1602, hp1604, hp1605, hp1606 and hp1608.
Feb 02, 2013 | Norelco 3405 LC Electric Shaver
Are Norelco HQ9 Blades interchangeable with HQ55 blades?
philips norelco HQ56 replacement heads compatiable noelco HQ55 blades.
Does the Norelco 725RL corded razor have self-sharpening blades? I understand that it uses HQ4 plus replacement blades. Are they self-sharpening?
The HQ4 blades are self-sharpening. The manufacturer also suggests changing these every 12 months.
If you require new HQ4 blades, you will find them available at shaveroutlet.com. See link below
http://shaveroutlet.com/specials/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
Sep 25, 2010 | Norelco ReflexPlus 6423 LC Electric Shaver
Health & Beauty Logo
1,200 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
