Question about Microsoft Wireless Optical Desktop Comfort Edition
Keyboard want light up but mouse works
I have buttons on my microsoft comfort keyboard that will not light up. The mouse works fine, it just the board. I also do not know how to use the many keys that I have on it, there was no manual in the box, when I bought it.
  • eilhin Oct 24, 2008
    This is a Microsoft Wireless Comfort KeyBoard 1.0A, Model: 1045
  • Anonymous Apr 06, 2009
    yes
  • 35 Answers
The buttons on the top (silver) are linked to your "Favorites" folder in Internet Explorer.
The buttons to the right of that are used for your media player (To skip tracks and adjust volumes, play pause etc)
The buttons on the left (from top to bottom) are:
1) My documents folder will open
2) MSN or Windows Live! Messenger will open
3) Your E-Mail will open (whatever your default email program is)
4) Calculator Opens
5) Windows Update will open
Now... In order for these you HAVE to have the drivers installed. If you didn't get a CD with your keyboard, you can download the drivers directly from Microsoft here:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Just fill in the drop-downs and press "Go", it should show you a link the the exact driver you need to install. Once it's been installed you can set up your favorites with the software that it installs.
Posted on Oct 24, 2008
    Genius:
  • 1,605 Answers
Try one of the follwoing method:
there is no users manual. if you are useing Windows Operating System it all need is to plug in the USb and setup the mouse and the key board one at a time. the setting should appear in the control panel.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Keyboard want light up but mouse works - uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx)uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Can't install a Microsoft Wireless Comfort keyboard. I installed the mouse via the USB and IT is working. The keyboard has new batteries. I pushed all 3 buttons...the mouse, the keyboard and the USB thingy...
did the keyboard come with a driver (CD) , if so , reinstall it
if possible, would you be willing to reinstall the recovery Cds to your computer to have a clean set up ?
do you have the recovery Cds -- this means formatting your disk drive --sure, you can back up your important stuff, but i think a reinstall of the recovery Cds is good for the entire computer
what about virus s/w -- what do you use ?
Oct 16, 2010 | Microsoft Wireless Optical Desktop Comfort...
My microsoft wireless comfort keyboard 1.0A will not operate. I've changed the batteries and gone through all the troubleshooting. I am using this in conjunction with the wireless mouse which works. I...
there are three reset buttons one on the bottom of the mouse and one on your keyboard's backside and there is a reset button on the receiver that plugs into the USB press all at once untill lights flash and try to get it to connect again.
or try to
1- use "Reset" (in you case it might be "Connect") buttons on your keyboard's backsid and also on receiver.
2-use "Reset" (in you case it might be "Connect") buttons on your mous's backside and also on receiver.
If all the above did not work do open the keyboard it self and make sure the areal (a wire beside the frame going all around the edge of the keyboard inside) is connected to the circuit board if not reconnect.
hop this will help.
Nov 20, 2009 | Microsoft Wireless Optical Desktop Comfort...
I have the microsoft wireless mouse and keyboard, was working fine, i cant get it to connect now. i need help
or try to
Oct 01, 2009 | Microsoft Wireless Optical Desktop Comfort...
Microsoft Keyboard (1045) doesn't work with new Samsung Monitor
Hi
Keyboard and mouse have no connection with Monitor
Since keyboard and all are linked with mother board
so firstly i suggest you yo check the wireless connections are ok
Now reinstall the software packages that came with the keyboard(And drivers)
i hope this will help you
Mar 23, 2009 | Microsoft Wireless Notebook Optical Mouse...
Can't install Microsoft Wireless Desktop
you need to resync the mouse and keyboard to the wireless receiver. you hold the button down on the receiver until you see a flashing light and then you press the button on the bottom of the key board. then you do the same thing for the mouse.
Feb 27, 2009 | Microsoft Wireless Optical Desktop Comfort...
MICROSOFT WIRELESS COMFORT KEYBOARD
my keyboard and mouse are usless after installing vista trasmister lights bearly glow nothing works.
Oct 04, 2008 | Microsoft Wireless Optical Desktop Comfort...
Microsoft Wireless Optical Mouse Not Connecting
when do resetting chk whether u are getting blinking light on mouse. if yes and after resetting the light is steady then ur mouse if fine. if u are using vista then use the os disk go to the os installation screen and chk whether the mouse is active there. if yes then reinstall drivers or update it.
Sep 21, 2008 | Microsoft Wireless Optical Desktop Comfort...
Keyboard stopped working when I changed batteries
PrtScn button does not work and attempting to have it repaired as i am certain the software has been downloaded properly
May 01, 2008 | Microsoft Wireless Optical Desktop Comfort...
Microsoft Wireless Comfort Keyboard 1.0A in Vista 64bit - intermitant
You can download the driver from the following website. Make sure to select Vista 64 bit from the drop down menu.
Feb 21, 2008 | Microsoft Wireless Optical Desktop Comfort...
Microsoft Wireless Optical Desktop Comfort Edition Logo
588 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
