Question about Exercise & Fitness
Dk city treadmill drive board circuit diagram
Giving eror 1
2 Suggested Answers
SOURCE: Wiring diagram need for an Smoothfitness EVO treadmill.
Solved this problem by contacting the Evo/Smooth directly. Great service.
Posted on Oct 20, 2009
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
Eror moter system fault
test the speed sensor, adjust it,clean it, and tight the plug or connector very well.
2) Test the input voltage motor, if there are the motor need repair see my personal TIPS for troubleshooting motor
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram attached.
God bless you
Nov 28, 2012 | Startrac Fitness Products Star Trac Pro S...
Rev11301 treadmill
see the block diagram and diagram attached. 1)You need to test with DVOM a) transformer b) main switch c)power supply(diode, capacitor,IC regulator) for short circuit d) coil e) and main board too, Disconnect every device one by one, and see what is giving the short.
God bless you
Nov 14, 2012 | Reebok Exercise & Fitness
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
My sports art 1060 when give it power the screen power on but not work
1) adjust the Reed switch, clean, and tight the connector very well.see the diagram attached.
2) Tight the ribbon cable from keypads, very well, and clean.
3) Tight the connectors from display board vs lower board.
See the diagrams. God bless you
Jun 02, 2012 | Sportsart 6300 Treadmill
Circuit to treadmill tripped when motor starts
1= this syndrome is lack of LUBE in deck belt, you must do it right now.
2= Test the motor for input voltage, if there are , the motor need repair.
3= Test the output voltage board, if there are NOT, the board is faulty
see the block diagram attached. God bless you
May 15, 2012 | Life Fitness 9100 Next Gen Treadmill
How to fix a treadmill thats not working and is giving an error sign
1) replace new ones batteries
2) adjust sensor reed swtich by 1/8" or 3 mms see the diagram
3) tight the flexible cord from keypanel vs display board .
4) tight connector from display board vs lower board(main motor controller board)
5) see block diagram how the main motor controllerh has 90% aprox functions from any treadmills.
Dec 16, 2011 | Body Solid Best Fitness Treadmill
I have an older proform 785 treadmill thats giving a E21 error???
This is indication Powerfully that Main controller Drive Board is demanding Enough Current .
This indicate 1) walking belt is worn or 2) the drive motor brushes are worn.
3)Leaky filter capacitor 4) inductor or coil faulty.
You must use A clamp-on ammeter for determine the amount of A.C. input current being drawn by the treadmill under Load and Not Load.
See the Block diagram for knowledge how the main controller board has aprox 90% of function of the treadmills. Good luck.
Now you will have the Strong Results for trouble what is wrong!.
This block I did for Motivation Troubleshooting.
E.CUADR
MANAGUA, NICARAGUA. C.A.
Nov 26, 2011 | Proform 785 Treadmill
Exercise & Fitness Logo
64 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
