Home | GE | Profile JT910SASS Electric Single Oven | GE Profile Wall Oven Mod...
GE Profile JT910SASS Electric Single Oven
Problem for GE Profile JT910SASS Electric Single Oven
GE Profile Wall Oven Model JCKP16GS-1
By cgish on Oct 24, 2008
Getting F3 and F2 codes on the readout. Sometimes works, sometimes doesn't. Have had the temperature sensor replaced and we're still getting an F2 on occasion. When we get the error code, the oven won't work. Have turned off the breaker to allow oven to reset and it doesn't help. However, the oven may decide to work again the next day.
We've had service out twice, once to replace the sensor. Second time, they didn't know what the problem was and the oven decided to work when he was here.
Any suggestions?
Comments:
Mar 05, 2009
- This probably was the solution. We called for service again and the serviceman did a thorough cleaning of some of the components (not sure which ones). Since then, the oven has worked perfectly.
Best Solution
posted on Mar 04, 2009
Helpful)
cargurudude
Rank: Master
Rating: 84%, 12 votes
It sounds like this is a common occurance among GE ovens.
Shut off the power at the box, then remove faceplate then remove the keypad.
after doing so, remove it from connector, and clean pins with an eraser.
Make sure the terminals are clean of debris, and check for a reset button on the back of the keypad.
I hope this helped you out.
Was this helpful?
Yes
No
Popular Solutions for GE Profile JT910SASS Electric
Questions and Unsolved Problems for GE Profile JT910SASS Electric
Do you recommend GE Profile JT910SASS Electric Single Oven?
Answer
Answer
We woke up to the stove beeping and flashing F7 in read and EA to the right in green letters? We... (More)
Answer
We tried disconnecting powe and it briefly went off. When we tirned the oven on it shut down and the... (More)
Answer
I have this model oven from the USA but am living in Europe. Anyone know how I can connect this for... (More)
Answer
Oven seems to be shut off but convection fan keeps running.
Answer
I can enter bake and temp but when i press start nothing happens so the oven never turns on...help... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile JT910SASS Electric...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
