I can't connect it to my pc to put some tracks or file.
SOURCE: How Do I Reset My MP-C543 MP3 Player If I Don't Have The Manual ?
I had this happen to me twice. Give me a few minutes & I will post the directions on what to do. FYI...it sucks. You have to completely reset the mp3 player & add all the songs on again. PIECE OF ****!
SOURCE: Lost software on Rave-MP AMP512 MP3 Player!
Here is the firmware upgrading tool for Rave-MP AMP and ILO256 MP3 Players:
http://www.filefactory.com/file/d6cbe0/n/Rave-MP-Install_exe
SOURCE: Technika MP-408 2GB Video MP3 player with FM tuner
I bought my MP 408 yesterday and had the same problem. I looked inside the packaging just before I threw it away and noticed a small cd. On the CD you will find the manual and a video to SMV converter. Create a file where you can copy the video to SMV converter software into and create a shortcut on your desk top.You are ready to go, connect your player and start the software. set the destination file to MYvideo on the player, add the file you want to convert using the add button and click on the convert button and that's it. you can resize the video screen size prior to converting if you need to via the on screen panel on the righthand side of the screen.
one thing not related to this problem in any way but you might like to try this and that is throw away your ear phones you got with the player and put some reasonable headphones on and you will be amazed how good this little box sounds especially if you tweak the built in graphic equalizer, have fun,
Brian
SOURCE: My Technika MP707 MP3 player
I think that the instructions are not as fulsome as they could be. Once you have downloaded to the file called voice you need to right click on the briefcase and go to move to and then move to the drive you are using - in my case drive G. This should be done after instruction 4.4. Also the taskbar icon is hard to see but it is the one with the green arrow pointing south west.
SOURCE: I have a technika mp-111
did you fix it? i'm having the same trouble - this 'mp4' player is the worst!!!
