Question about Hardware & Accessories
Instructions to set up 24 hour compact pin timer from B&Q
5 Suggested Answers
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Posted on Dec 18, 2009
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
  • 396 Answers
SOURCE: I just purchased a Woods TN300 Timer. I have it
Make sure the manual override switch on the unit is set to timer on.
Posted on Aug 10, 2010
  • 414 Answers
SOURCE: wondering how to use a
Pins are usually up for on and down for off, so put them to on for the times you want the lamps on and vice versa, obviously you can check firstly to be sure which way is on and which way is off.
Posted on Jan 07, 2011
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Hello, I have a es107 connect-it timer, do you have instructions for it, please. Many Thanks Glennis
I do not have manual specific to that timer.
ES 107 timer appears to be 240Volt analog 24-hour timer with 15 minute segments located around edge of dial.
http://p.mdcd.net/product_images/full/f21276b30757d43b9c32a6c12eb4695d7e02cfdb.jpg
Here is generic manual for Lamp timer that has identical 24-hour dial to ES107, but is rated for 120Volts and has red button on side:
http://waterheatertimer.org/pdf/Chicago-lamp-and-appliance-timer-40148.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Chicago
Here are generic how-to-set instructions:
Aug 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Hi how do i set the the 59200 timer for indoor use. does it matter if you use the nos on the white side of the dark side of the timer? im not following the instructions. how do u know how many pins to...
Each pin/segment represents 30 minutes.
To set timer for 2 hours, move 4 consecutive pins/segments up or down.
For 8 hours, move 16 consecutive pins/segments
http://waterheatertimer.org/images/Raise-segments-240.jpg
Dark background for numbers are usually 'night' or 6pm to 6am.
Timers usually have am and pm printed on timer dial.
Open following link for analog timer instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Jul 18, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
How to set my grasslin pool time trying to understand to let it run in day and shut off at nite about 6pm so i need to set it that way with the pin
Open following link for setting Intermatic/Grasslin FM1 timer setting instructions:
To set the 24-hour analog timer, you need to move 4 consecutive tripper pins for each hour of run time.
So for 6 am to 6 pm, 48 trippers pins will be moved outward and 48 inward.
http://waterheatertimer.org/pdf/How-to-set-Intermatic-FM1-timers.pdf
Open following link for Intermatic FM1 series and PB series modular timers with wiring, manuals, model numbers and instructions for setting.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
Wondering how to use a 24 hour compact pin timer to automaticlly turn on my lamps ?? bought 1 yesterday but no clue of how to work it !
Jan 07, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I need instructions for how to set a 24 hour mechanical General Purpose timer. My model #15075
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Oct 25, 2010 | Electric Eyeware Ge 24 Hour Electric...
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
837 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
