Question about Philips Televison & Video
My remote for my tv is playing up, All the buttons do different things to what they are supposed to. the remote is philips rc19039001/01h Any ideas to correct it?
  • 35 Answers
1) Replace the batteries.
2) If that doesn't work, it's probably been dropped too many times or something spilled on it. Just replace it. They actually sell Universal Remotes at some dollar stores. If not, $5-$10 is the most you need to spend on one.
Posted on Oct 24, 2008
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
    I suggest you try these steps..
    1.Turn the television set on by pressing the "Power" button on the set.
    2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
    3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
    4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
    5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
    I hope this helps...
    Jun 10, 2010 | Philips Magnavox Learning Universal Remote
    I AHVE A HD PHILIPS TV ,IHAVE ABSOLUTLEY NO SOUND ON THE STANDARD TV ,I ONLYHAVE SOUND IF I PLAY A DVD MOVIE. RIGHT NOW THE SUPERBOWL IS ON AND I CANT HEAR A THING.PLEASEHELP.
    when you play a dvd, do you have to select aux, or video channel to play this ? if so select tv on your remote, not a solution, just an idea.
    Feb 08, 2010 | Car Audio & Video
    Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
    Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
    Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
    How can i unlock philips hotel tv 21ht3302/41? -to play dvds
    use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
    319753 mute
    Jun 30, 2009 | Philips 20PT6441 20" TV
    Using remote control on philips tv
    Unfortunately, you can't.
    The remote controller does have buttons on it to adjust a TV but these will only work with a Panasonic TV. Because your Phillips control codes are different, and the remote controller does not allow its send code to be adjusted, they won't talk to each other. The only thing you can do is get a universal remote and program it for both, or buy a Panasonic TV.
    Apr 07, 2009 | Panasonic DMR-E55 DVD Recorder
    Bought TV from hotel not getting channels and not playing dvds
    in the menu usually a button on tv switch from antenna to cable or catv
    if you remote won't work there are 7 or 8 different code choices go through them till it does work
    most unversals need tv on and will turn off when code is right
    also in menu is audio choices stereo on /off and so on play in there till you get it
    Dec 26, 2008 | Philips TV Tuner Video Capture PCI Card -...
    How to set the telelvision to use a dvd,
    On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
    Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
    DVD operation
    scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
    wg
    Feb 16, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
    Televison & Video Logo
    52 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
