Gas pak intertherm - heat will not blow, and fan will not shut off while on heat, possible faulty thermostat?
  • LlGgBb Nov 24, 2008
    Cold air is blowing, will not turn off. How do you confirm if it's the ignition?
    New Friend:
  • 30 Answers
It is not the thermostat. the fan you hear is likely the vent fan which will run continuosly if there is a problem with ignition. this is to give you an audible signal that something is wrong
Posted on Oct 30, 2008
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Intertherm M3rl080A BW furnace that shuts down will no indication of fault
If your diagnostic indicator is not picking showing a fault code than it thinks everything is ok with the furnace. It could be a bad thermostat. (or the heat anticipator in the thermostat).
Jan 30, 2014 | Intertherm 56000 Btu Gas Furnace
Our fan for the intertherm p3ra-024k will not shut off. We have put new wiring from thermostat to unit. He pulled the green wire like the serviceman told him to when he serviced it and it still keeps...
You have a problem with the wiring somewhere it could be in the thermostat. When the service man said pull the green wire off that was the power to the fan. The thermostat should wire up as red to the R terminal on the thermostat this is the 24 volt feed to your thermostat and to the unit. The white wire should hook up to the W terminal on thermostat. This white wire is to the heating section of your furnance it activates the heat mode. The yellow wire hooks up to the Y terminal on the thermostat this is the outside condensing unit control for the a/c. The green wire should hook up to the G terminal on the thermostat this is your fan wire that activates the blower in your furnance If this wiring isn't hooked up as such then your problem is in the wiring from thermostat to units inside and out. Also if you have changed the thermostat you need to be aware of the setting for the thermostat and the type unit you have. Most thermostats are universal however, you need to make sure that on the thermostat the setting for heat pump on the thermostat it will have a small switch and on switch will have hp at the top and nonhp at the bottom. If you have a heat pump you need to make sure that the setting on the thermostat is on hp if not a heat pump nonhp is the setting. Also there will be a switch that has g at the top and e at the bottom This is you gas or electric heating seletor switch make sure this switch is in the proper position for either gas or electric heat. Good luck on your repairs Hope this helped
Dave
Nov 02, 2009 | Intertherm P3RA-024K Air Conditioner
I have air coming from the vents but no heat. The furnace is 23 years old and I've never replaced anything in the unit. Best guess? GE Intertherm. thanks
If the thermostat is set on Fan and not Auto the fan will continue to run. If the fan control is bad or is set at too low of a setting, it will blow cold air after the furnace has shut off. From what I guess of your explanation, your furnace is not producing any heat and the room air blower runs blowing cold air. You may have two issues happening. Make sure your thermostat is calling for heat by setting it to a high setting. Inspect the thermostat to see if it is set at Auto. Go to the heating system and inspect it to see if it is heating. If you can't view any flames carefully touch the exhaust pipe and see if it is hot. If not, you have a no-heat condition. A 23 year old furnace may need some TLC so call a technician you trust. He/she may need to replace the ignitor or thermocouple to get it going. They will also check out why your fan is running when it should not.
Nov 02, 2009 | Heating & Cooling
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
