I have a LG WD10150TP with an error message 0E, please help?
When try to run a wash cycle, the cycle stalls close to the end and in the timer window the message of 0E comes up. The door can be opened and the clothes are soaking wet. I'm gathering it's a spin issue. When I run a wash cycle on its own with no clothes the same message comes up and there is water about 2cm deep in the bottom of the machine. Please help.
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
jsrock516
  • 5911 Answers
SOURCE: Washing machine stops in rinse cycle.
Okay...I asked you a question in your other posting before I saw this one. This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plunger on the lid itself. Make sure the plunger is not broken off. This will also keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and agitate, but will not start the rinse or drain cycles. If you wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Feb 11, 2008
SOURCE: clothes are soaking wet at
This worked for me!
Posted on Nov 26, 2008
  • 107 Answers
SOURCE: My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Posted on Mar 13, 2009
  • 1122 Answers
SOURCE: clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Posted on Apr 18, 2009
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Error code 0E
OE is OUTLET ERROR.
More often than not, a blockage is in the pump(not that easy to get to and quite a long step by step process)
You might also find the blockage at the end of the drain hose, where it connects to the drain pipe- remove the hose clamp and inspect hose and spigot.
May 04, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Maytag Washer, Neptune TL
This means the computer is not seeing that you opened the lid between cycles 3 times. So likely the lid locks are faulty. PLEASE rate my help as solved all other ratings dock us
Oct 02, 2007 | Maytag MAT13MN Top Load Washer
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
