Question about Philips GoGear HDD6330 MP3 Player
Music files on my player that wont play
When i turn on my player on it only brings up some of the music files and others dont show. yet on the computer it shows all files
  • oconnorp1 Nov 10, 2008
    i have the identical problem. WMP shows the disc as full of my music but the device itsself does not display them. I cannot get WMP to delete or reinstall files from WMP.
    It appears that the device is not compatible with VISTA or with WMP11. I have recently had to replace my PC. As virtually all new PCs are now shipped with Vista rather than XP, it means your Phillips MP3 becomes instantly obsolets.
    I understand that Phillips dont intend to provide a fix. If so, this shows an arogant contempt for their customers I shall not be buying Phillips products in future.
Try converting it to another file format
Posted on Nov 17, 2008
My download music won't play
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
May 08, 2012 | Kobian HipStreet T-29 2GB MP3 Player
There is bootex file that freezes files and wont delete or let me download music to it.. it has only 6 songs will play them. On properties it shows to have 175 files but dont show on mp3
Hi ==) ^^
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Jul 08, 2010 | Memorex MMP8565 MP3 Player
MP4 player not playing music
Download the special firmware of your daughter's device , after that you shouldn't forget to restart it . The special firmware could be found on the manufacturer website .
Jan 20, 2010 | Audio Players & Recorders
Having problem syncrinizing music to mp3 player
if u used window media player its will mess up your mp3 by duplicating songs and not leting u play songs. What i do is connect it to the computer and it should pop up. DONT open window media player. Open the files and add your music by dragging them into your mp3 from another folder. This only works if you have a different folder of music. It should work. If all your music is in Widows media player it wont work. Also try deleting all your music from ur mp3 but copy your musice onto your computer first. Good luck i hope i helped.
Apr 08, 2009 | Philips GOGEAR SA6045 MP3 Player
Mp3 not playing music in device
check your file type that you are putting into the mp3 player. This is a common mistake. Most accept MP3 but not other file types such as WMA from windows media player or AAC from Itunes. If all that is good then check where on the mp3's file system the files went using my computer. If they arent in the right folders than they might not show up
Mar 15, 2009 | Acer MF35 MP3 Player
It keeps saying file error
Check the format of the music you are playing and if you have music that requires the license it will load the music but not play. It will show up as a file error.
Feb 28, 2009 | Coby MP300 MP3 Player
My Sansa Shaker wont take the music.
check the file types from you music the shaker only plays MP3 and PCM WAV  file types. You may have WMA (if u used windows media player) which will not play on the shaker  (i had this same ploblem btw) you can easly find free music file converter software to change these files to mp3 or wav types (which i did), or you could rerip to songs from a cd and tell the windows media player to rip the files as mp3 types instead of the default wma format  from the windows media player widow :
tools >> options >> Rip Music >> under format select mp3 (theres a wav option but i used the mp3 option to be safe)
do not use the sync feature it will automatically convert your files to to wma (why? i dont know) instead copy the files directly from the folder that contains them :
right click the file you need to put on the player select open file location drag and drop to the player (or copy/paste if you want).
hope this helped =P
Dec 28, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Music will not play from mp3
make sure the music file is mp3 and check if u put it on the music folder
Jan 12, 2008 | Audio Players & Recorders
Delstar ds 801 mp4 1gb
For the 10 second play problem the player has been set to intro mode, which only will play the first 10 seconds of each song. While it is playing, press the mode button ( bottom right ) once. This brings up the play sub-menu. It should show " repeat" as the first item. Press mode button again and it should show "intro". Now press either the top or middle buttons on the right side once, this shows all repeat choices again, using the same buttons scroll through them till "normal" is highlighted. Then press the bottom right button again. This shoudl put it back in normal play mode and return to the music screen.
Dec 26, 2007 | Delstar DS 917 Digital Media Player
Philips GoGear HDD6330 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
