Question about Sanyo DS20930 20" TV
Coaxial output broken
I have the coaxial output (where you connect the antenna coaxial cable)broken and the metal piece came out otherwise everyting else in the tv is working.
Does it take much to fix if I open the TV? Did anyone fix such a problem before?
  • sanyofix Oct 29, 2008
    Thanks
    A shop fixed it for me for 30$ thanks
  • 4 Answers
If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
Posted on Oct 26, 2008
I have a Channel Master amplifier model 3042 to increase the antenna strength on my TV and don't know how to connect it uh it's a Channel Master model 3042
Coaxial cable from Antenna to input on amplifier. Coaxial Cable from output of amplifier to Television, VCR or AV Receiver depending on what you have hooked up.
Nov 13, 2014 | Televison & Video
SWR displays briefly then back 1.1
Your problem is not very well described, but let me guess: while you transmit, SWR peaks shortly to a high value and then drops back sharply.
There are two possible reasons:
1) Strong radio transmission pulse somewhere very close to the antenna;
2) Bad contact between connector and coaxial cable somewhere between SWR meter and antenna. Points to check:
- Coaxial connector on the cable from SWR. Is it soldered properly?
- The coaxial cable: can you see mechanical damage, stress? If you find scratches, broken isolation, sharp bends, etc, try to replace the cable.
- Connection between coaxial cable and antenna (or connector): is it soldered properly, is it not corroded or mechanically damaged?
- Connections inside the antenna (if there are any such joints): look for corrosion and mechanical damage, also loose screws.
If you find multiple places of potential problem, go step by step from antenna towards the SWR meter: if the most distant problematic location is fixed and it still shows this strange behavior, go closer.
Rarely this could be a problem in the SWR meter itself. That can be identified if you replace antenna by a dummy load. Dummy load should never cause bad SWR "flashes" (unless it is mechanically broken, too).
Mar 30, 2014 | Cobra 29 LX
Can't hear anybody
First, stop transmitting. If your antenna system is compromised, transmitting can cause damage to the output transistors are require an expensive repair to correct.
Carefully check the entire length of the coaxial cable from the rear of the radio to the base of the antenna. Pay attention to pinch points between body panels, door openings, etc. Crushed coaxial cable results in a short circuit and must be replaced. Chafed or an otherwise damaged outer jacket on the coaxial cable will allow water to enter and contaminate the dielectric and oxidize copper braid and center conductors. This type of damage requires replacement, too.
Inspect the connector at the radio. Make sure that the soldered joints in the connector are still secured and have not broken and caused an open circuit or short circuit. This connector should be snugged up hand tight to the radio's connector.
Check the feed point of the antenna. This connection is often subject to moisture and can oxidize quickly. Look for evidence of oxidation and other open or short circuit conditions here. Cut the coax back until all the oxidized cable is not longer visible and reconnect to the antenna feed point. If possible, coat this connection completely in a thin coating of silicone to keep water from attacking the connections or entering the coaxial cable.
Check any connections between the antenna base and the antenna itself. Many antennas allow for removal for car washes, etc. by unscrewing / quick disconnect from the base. Clean threads or retaining pins on both the base and antenna thoroughly. Check the center pin contacts on the base and antenna for evidence of good contact. Oxidized surfaces here can indicate a poor connection. Clean or replace as needed.
Make sure that the surface to which the antenna is secured (tool box) is solidly grounded. One or more large conductor bonding jumpers from grounded vehicle panels, frame, etc should be extended to the tool box. A tool box that merely sits on / bolted to the truck's bed is probably not providing enough contact with unpainted, grounded body panels to provide sufficient ground for the antenna system to work well.
Check the tuning slug at the end of many fiberglass antennas. It should be present, and have the protective cover to seal out the entry of water.
Lastly, after the above has been addressed & corrected, tune the antenna to the radio on the truck with a quality SWR meter for the frequency range of the CB as per instructions.
I hope this helps & good luck!
Apr 16, 2012 | Cobra 19 DX IV CB Radio
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    I recently purchased an LG RH397D dvd recorder> Ihave now discovered taht it will not receive the new free view channels and I need a HD set top box. How to I connect the set top box to the dvd...
    Hi, The set top box will more than likely have two coaxial connectors ( threaded/ribbed pieces of metal ) coming out of the back. also three R.C.A. connectors-these will be smooth and be colored yellow red and white. one of the coax connectors will say " IN FROM ANT> or CABLE IN) the other ( OUT TO T.V. ) hook up your dvd recorders " ANTENNA " input to the set top box's ANTENNA output. If your D.V.D. recorder doesn't have an antenna input then hook up the recorders audio/video input to the set top box's audio/video output. then you should be good to go. If you buy a H.D.T.V. tuner to receive FREE H.D. programming it may be possible to hook up to recorder with H.D.M.I. cables.( those connections resemble slots ) I hope this has been of some assistance, good luck, Prodzilla.
    Apr 02, 2011 | LG Televison & Video
    On the back of my kenwood receiver there is a jack connection for FM reception-Antenna. The jack is too small for a coaxial connection. Is there an adapter to connect a coaxial cable to the back of my...
    It's the F antenna connector. You can use a connector like this one in order to connect your antenna or put in the hole f the connector just the inner copper cable of your antenna cable and stabilize the outer thin cables from your antenna cable at the outer metal part of the F connector (using a small cable tie). There is no dangerous voltage at this connection so don't worry about safety (at this connection).
    In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct FixYa link: http://www.fixya.com/users/technical114
    Sep 22, 2010 | Kenwood Audio Players & Recorders
    How to connect a sv5000 on a very old tv?
    Does the SV5000 have a coaxial (Channel 3 or 4) output? Connect that output to the antenna input to the old TV. If your TV is so old that it has only a 300 ohm antenna input (2 screws), just use one those old adapters that has 2 scew lugs on one end and a coaxial receptacle on the other, connect a coaxial connector between that and the VCR's coaxial output.
    May 13, 2010 | Samsung SV5000W VHS VCR
    Replace antenna
    Remove old Antenna
    1. Activate the antenna switch to the up position.
    2. Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
    3. Gain access to the underside of the area of the trunk where the antenna is located.
    4. Remove the bracket or brace that is below the hole and holding the antenna in place.
    5. Remove the mast.
    6. Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
    7. Remove the ground lead from the panel.
    8. Pull out the antenna coaxial cable.
    9. Unplug the coaxial from the extension coaxial cable.
    10. Remove the original antenna coaxial cable. Note the route the cable follows.
    Install new Antenna
    1. Inspect the fender area where the antenna mast will be mounted for rust.
    2. Clean the area before installing the new antenna.
    3. Plug the new antenna coaxial cable to the extension coaxial cable.
    4. Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
    5. Connect the power lead of the antenna to the power antenna lead on the radio.
    6. Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
    7. Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
    8. Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
    9. Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
    10. Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
    11. Stop the motor after the cable goes into the housing 12 to 25 inches.
    12. Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
    13. Replace the retainer nut to the base of the antenna mast and secure tightly.
    14. Replace the panel that covers the antenna mount area.
    Oct 16, 2009 | 1996 Honda Accord
    Antenna mast broken
      Give these instructions a shot. Might be too generic but might be enough to get you going. Removing Original Antenna
    1. Step 1 Activate the antenna switch to the up position.
    2. Step 2 Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
    3. Step 3 Gain access to the underside of the area where the antenna is located.
    4. Step 4 Remove the bracket or brace that is below the hole and holding the antenna in place.
    5. Step 5 Remove the mast.
    6. Step 6 Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
    7. Step 7 Remove the ground lead from the panel.
    8. Step 8 Pull out the antenna coaxial cable.
    9. Step 9 Unplug the coaxial from the extension coaxial cable.
    10. Step 10 Remove the original antenna coaxial cable. Note the route the cable follows.
      Installing the New Power Antenna
    11. Step 1 Inspect the fender area where the antenna mast will be mounted for rust.
    12. Step 2 Clean the area before installing the new antenna.
    13. Step 3 Plug the new antenna coaxial cable to the extension coaxial cable. (On some General Motors and Ford cars you may need an adapter to mate the 2 cables together. Car audio retail stores sell such an adapter.)
    14. Step 4 Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
    15. Step 5 Connect the power lead of the antenna to the power antenna lead on the radio.
    16. Step 6 Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
    17. Step 7 Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
    18. Step 8 Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
    19. Step 9 Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
    20. Step 10 Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
    21. Step 11 Stop the motor after the cable goes into the housing 12 to 25 inches.
    22. Step 12 Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
    23. Step 13 Replace the retainer nut to the base of the antenna mast and secure tightly.
    24. Step 14 Replace the panel that covers the antenna mount area.
    May 13, 2009 | 1993 Chevrolet Corvette
    Sanyo DS20930 20" TV Logo
    215 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
