Question about Refrigerators
Where can I get a gasket for my valira corkscrew?
I have a Valira automatic corkscrew and I lost the rubber ring (gasket) that is on the inside where the top of the wine bottle meets the opener. Thanks!
5 Suggested Answers
SOURCE: Replacement o-ring
I have the same problem with my Valira expresso coffee maker. If the manufacturer does not supply extra gaskets, as they should, when the coffee maker is purchased, forget about trying to purchase them. Instead, bring the broken seal to a hardware store and find material to use, using the old one as a template. Most hardware stores have assorted sizes of round gasket that can be adapted.
Posted on Jun 02, 2009
  • 121 Answers
SOURCE: Temp. is on automatic settings for
temps will fluctuate. depending on door openings and defrost cycles.no abnormal noises heard on the ones ive worked on but appliances tend to be noisier then they were. if less than a year old have an authiorized servicer go out and look at.
Posted on Sep 16, 2009
  • 905 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
  • 13 Answers
SOURCE: How can I change the Corkscrew Spiral on a Rabbit Deluxe Wine Bottle opener?
Drink beer
Posted on Jul 02, 2014
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
I dropped the lid to the pentair 320 chlorinator for inground pools. The rubber gasket fell out and I don't know where it goes nor does it fit inside the lid. Do the gaskets go inside to screw on lid...
Yes, the o-ring does swell up. I am not really sure what causes that, but the only fix is to replace it. It goes inside the cap. Only use teflon or silicone based lube on it.
Jul 23, 2013 | Pool & Spa
I need a new Rubber safety seal for the Isabella inox 18/10 where can i bye it in the netherlands ??
I have send a Email to the factory, for oder a new one
many thanks R Verstraaten
Dec 27, 2009 | Valira Isabella
I need a replacement rubber gasket for Six cup Cafetera Isabella
HI
You need to contact the manufacturer here
http://www.valira.com/eng/index.html
Feb 19, 2009 | Valira Isabella
Replacement o-ring
Sep 08, 2008 | Valira Claudia Coffee Maker
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
