Question about Nokia BH-503 Bluetooth Headset
Steady blue light while charging nokia bh 503
SOURCE: i have made connection between
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
Posted on Dec 26, 2010
esound
  • 425 Answers
SOURCE: pairing pin for Nokia BH-503 and E63
HI,
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
A
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Thank you using fixya..
Posted on Jan 14, 2011
SOURCE: The Nokia BH 503, when
i have put my handsfree on charging when i have remove the charger it still showing red light
kindly help me it's urgent
Posted on Apr 23, 2011
  • 3 Answers
SOURCE: I recently bought Nokia BH-503
I'm facing the same **** with Nokia bh-503 it worked with my dell inspiron n5010 for few days but now it says pairing failed
this is really ******* waste of money..........
Posted on Jul 16, 2011
SOURCE: Compatibility issues between Nokia BH 503 headset
my nokia is having a headphones issue
when i attach headphone wid my nokia 5233 it also show a notification like headset connect bt do not give sound in ear phones
i hav try many compatible headphones but it is still not working
Posted on Sep 15, 2011
My Nokia BH-503 Suddenly Change in to ISSC-SHS and not charging
How long have you had this item? It could be the lithium battery in phone? I would encourage you to take the set up to Batteries etc: and let them check battery. Please leave me some feedback
Jul 08, 2016 | Nokia BH-503 Bluetooth Headset
I cant pair my nokia bh503 bluetooth headset with acer emachine netbook
First of all, you need to charge the BH-503 before connecting it to your gadget. On the BH-503 after it is fully charged, go to your gadget and turn on its Bluetooth. Mind you some gadget do not have embedded Bluetooth in them;all you do is to but an external Bluetooth and insert it in the USB port. That will make your gadget discover your BH-503. Pair the 2 together, I mean your BH-503 and your gadget and your up and running!
Jun 30, 2012 | Nokia BH-503 Bluetooth Headset
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
I recently bought Nokia BH-503 headset.It functioned normally for few days with my iPod 4G.But today suddenly when I switched it on the headset started blinking blue light without even pairing with my iPod...
Jul 15, 2011 | Nokia BH-503 Bluetooth Headset
I cannot pair my blackberry curve 3G with my Wireless Nokia headset BH-503! It was working until I paired it with another nokia 2700 and after trying to pair it with my blackberry curve 3G again, it...
It is paired with the Nokia 2700.
From the manual (Click here to get it) page 11;
To clear the pairing and volume settings, switch off the headset and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green and blue three times.
Feb 05, 2011 | Nokia BH-503 Bluetooth Headset
Nokia BH-503 Bluetooth Headset Logo
106 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
