Question about Cycling
Tension doesn't work on my schwinn srb 1500
Control panels works, but the doesn't seem be any tension adjustment
5 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: I purchased A Schwinn recumbant
I hope this will be helpful ..it is not a regular pdf one ..but a scanned one after the original ..
http://www.mediafire.com/file/v5o82qji2j6dacm/SRB-1500.pdf
Posted on Sep 05, 2010
SOURCE: cannot adjust the tension on
I have the same problem with a schwinn 202 that someone gave to me because the resistance adjustment no longer worked. They were advised by Schwinn that the motor needed replacement, but after testing mine, the problem seems to be a lack of power from the computer to the motor. Schwinn tech support will get a call from me tomorrow.
Posted on Nov 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: Schwinn Sidwinder gears need adjusting.
Keeping a derailleur in a given gear is the shifter's job. If the shift lever/mechanism doesn't click and stay where you place it, something is wrong internally. It will need to be replaced if, for example, a SRAM MRX grip slid away and let the guts fall out.
Whatever your particular dilemma, look for a friendly local bicycle shop to see what they can do for you. I replaced the entire MRX shifter set for a friend using an upgraded and better designed Shimano setup for under $25 and my own labor. But then, I'm an old hand at working on bikes.
For DIY:
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Posted on May 11, 2011
dunnbiker
  • 8546 Answers
SOURCE: need help getting rear wheel,
Search engine "how to install rear wheel"
Posted on Aug 18, 2011
Need owners manual for schwinn SRB-1500 recombenant bike
Try Schwinn.com, or ebay, search by model number
Oct 24, 2014 | Cycling
The tension does not increase on my schwinn 1800 srb
Does turning the tension knob, either direction, at the handle bars move the brake pads sitting near the rim of the main wheel ?
Feb 02, 2013 | Cycling
The tension does not increase on my schwinn 220
adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
My gears are slipping. how can i adjust them? the problem seems to be more in the 5th, 6th and 7th gear. this is a schwinn ranger mountain bike 2.6. it actully just started giving me a problem.
Sounds like your cable has stretched a bit and now the tension is off. There is a barrel adjuster where the cable comes into the rear derailleur. Turning this barrel too the right will increase the slack and turning it too the left will take up some slack.
Shift your gears to the middle of the cassette, then try turning the barrel 1/4 turn to the left, shift and see if it shifts into gear, if not shift back and adjust the tension again. Keep repeating till the gears line up.
if this does not work then it's time to take into a bike shop.
Apr 23, 2011 | Cycling
My son has a 26"
The disc brakes may seem like a new a completely different technology, but really they adjust basically the same as rim brakes. Both of your problems sound like the cables have too much slack in them. There is a mounting bolt for the cables at the brake, loosen that, pull the cable taught, tighten the bolt and squeeze the levers again. If that is better and the brakes don't drag, there you go.
If it still doesn't fix the brakes, then it is time to consider taking the bike into a bike shop and letting the mechanic have a look.
Apr 20, 2011 | Schwinn Cycling
Cannot adjust the tension on Schwinn 202. Computer is on but tension will not move up or down
Nov 21, 2010 | Schwinn Cycling
Schwinn SRB 1500 no resistance when peddling
just make sure that all the nuts and bolts are tight otherwise replace the cord which might have lost its strength and may have become elastic.
Jul 20, 2009 | Exercise & Fitness
Cycling Logo
96 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
