Question about Zodiac Pool & Spa
How to set temperature on pool heater zodiac onepac
5 Suggested Answers
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
  • 366 Answers
SOURCE: the zodiac works for seveal minutes, then the pool
sounds like you may have an air leak somewhere. If not from your zodiac hose, it may be in the plumbing itself. Check the threaded fitting on the suction side of the pump, check the pump lid o-ring, and depending on the pump, check the gasket between the hair/lint pot and the volute or seal plate (especially if it's a sta-rite).
Posted on Nov 22, 2009
  • 990 Answers
SOURCE: pool heater cycles on and
Check your by-pass valve to be sure it is closed and forcing water through the heater. Otherwise it will cause cycling and low heat rise.
Posted on Sep 19, 2010
aquaman987
  • 927 Answers
SOURCE: I have an RP 2100
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Posted on Nov 27, 2010
The freezer is set at -4. How do I adjust it? Everything is freezing too much.
Hi Marisa:
Following is the instruction for adjusting the freeser temperature for your Samsung refrigerator:
You press the freezer temperature button repeatedly till you see your desired temperature. If you want to set it to -2F, stop when the display shows -2F and don't press the freezer button again. After 5 seconds this new temperature will be set.
The instructions from the Samsung manual is shown below:
Controlling the Freezer temperature:
The Freezer temperature can be set between 8°F and -14°F to suit your particular needs. Press the Freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at 4°F. The temperature display will move sequentially from -14°F to 8°F. When the display reaches 8°F, it will begin again at -14°F. Five seconds after the new temperature is set, the display will again show the actual current freezer temperature. However, this value will be changed to the new temperature.
Feb 15, 2016 | Samsung RF265AA Bottom Freezer French Door...
The temp says 14 and 8 but should be -21 and 3? Can anyone help
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
How to set temperature on a general electric
Copied from ehow.com
Instructions
    • 1 Open the fresh food compartment and locate the two temperature control dials. Each dial is labeled for the compartment that it controls.
    • 2 Rotate the dial to increase the temperature setting by one to lower the temperature of the compartment. Rotate the dial to decrease the temperature setting by one to raise the temperature of the compartment.
    • 3 Wait 12 hours to allow the temperature in the compartment to stabilize before increasing or decreasing the temperature further.
Read more : http://www.ehow.com/how_8772966_adjust-temperature-controls-ge-refrigerator.html
Aug 28, 2014 | Refrigerators
How do I cancel a program a program and reset a time?
go into system set up and go to set time reset and go to program then highlight what needs to be changed edit or remove program
May 02, 2014 | Zodiac Jandy AquaLink RS OneTouch RS6 Pool...
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
0
F (1
0
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
0
F (.5
0
C), 2= + 2
0
F (1
0
C) and 3 = + 3
0
F (1.6
0
C).
SETTING THE TEMPERATURE SWING (TEMPERATURE DIFFERENTIAL)
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
MANUAL CHECK OF " SWING" OR TEMPERATURE DIFFERENTIAL
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
0
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
0
F.
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
Pool & Spa Logo
85 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
