Question about Refrigerators
I need an operating manual for a Westinghouse Freestyle fj303 freezer!
The red light with the word Alarm on it is on and everything in the freezer is only part frozen after the door was left open for an hour or so.
  • 1314 Answers
SOURCE: my westinghouse freestyle freezer model
that's the defrost timer it should cut off for thirty minutes for every eight hours of compressor time for self defrost now compressor time is not regular time as the thermostat shuts the compressor off every now and the when the freezer reaches proper temputure it works off accumulated run time and no you didn't turn anything that will hurt are you having problems with it cooling or you just noticed it was off
Posted on Mar 15, 2008
sodeep
  • 3267 Answers
SOURCE: Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
Posted on May 19, 2009
  • 3 Answers
SOURCE: my westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Posted on Jan 26, 2010
SOURCE: Westinghouse freestyle fridge. Fridge compartment
likely a malfunction somewhere in the defrost system, i.e., the defrost timer control, the defrost heater assembly, or the defrost bimetal thermostat
Posted on Mar 01, 2010
Testimonial: "Very helpful, thank you"
SOURCE: I have a westinghouse virtuoso
i have this fidge and suffer the same problem, i rang the company and it was only when i spoke to the manager he mentioned quietly to turn the fridge of for 5days with doors open to completely dry out the inside as its water gathering inside at the back and it worked the alarm stoppped, it was only cos i mentioned i couldnt afford hundres of $ for a repair guy, share the news it sounds commen in the model, ggod luck
Posted on Dec 25, 2010
My Westinghouse Freestyle Freezer FJ383 wobbles on the floor. How do I fix?
There are feet on each coner that can be turned to make them go up or down. you may need a person to slightly lift or tilt the unit and a pair of strong pliers to get the feet turning.
Jul 14, 2016 | Westinghouse Refrigerators
After defrosting, red alarm light on, green power light off. Westinghouse Silhouette FR393Q freezer.
Alarm means that the unit is overtemp for a freezer. Your breaker was likely overloaded if the same issue didn't follow the machine to the next outlet... If the alarm stays on when the unit is clearly freezing, you have some type of control problem. That model number is incomplete/incorrect.
May 25, 2016 | Refrigerators
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
Where can I download a service manual for my Westinghouse Upright Freezer Model FJ303 as I think there is something wrong with the defrost system
Go to Westinghouse web site and see if they are available there. If not , call them and have themsend one. Your defrost system is should be defrosting 2-3times a day. Is it not defrosting at all or is there an ice buildup.
Mar 02, 2013 | Freezers
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Red alarm light came on after we defrosted a westinghouse freestyle vertical freezer. what ius causing this pls. wilf
red alarm light is telling you that the feezer is too hot
(above 18c)it should go out when powered up and back to normal temp.
Mar 24, 2010 | Freezers
Hi my westinghouse freezer keeps turning itself off. there is a glowing red button and everything just defrosts and then it will turn itself on again, randomly. It is a freestyle 380litre with a 6 hour...
Freezers need a defrost timer to turn it off for short durations so that the coils are not so covered in ice that it can't transfer heat.  Make sure that you don't use an under-rated extension cord.  Check for any fans that may be blocked from turning.
Nov 10, 2009 | Freezers
My westinghouse freestyle frost free 650 litre is
Nov 08, 2009 | Westinghouse Refrigerators
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse fj383
I have a Westinghouse upright freezer FJ383M-R. The red light was on bright and the top half of freezer was not working. Turns out it was a switch that turns the defrost cycle on was faulty. Serveman replaced borken part. Now it is fine. Was much cheaper than replacing freezer.
Nov 28, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
903 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
