Question about Western Digital 2TB My Book Studio II Hard Drive
WD Drive Manager not installing
I cannot install the WD Drive Manager. That is: the install app. says "installed," but I cannot see that it actually _was_ installed. I need the program to reconfigure to RAID 1. Running on a newer mac mini, system 10.7.2. I cannot find the program on my computer (FIND: "WD" or "Drive" or "Manager" or "Smartware" - nothing yields results; force quit shows nothing, so it is not running in the background. I can access the My Book drive, however. the mac says it is 2T in size, so both units are being recognized.
SOURCE: win98se i did it ... HERE'S HOW
OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
Here are the drivers from this british webpage:
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Good luck to all you frustrated folks scooping your info off Windows 98 machines!
Posted on Aug 31, 2008
SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
Posted on Mar 08, 2009
bob_computer
  • 3153 Answers
SOURCE: WD My Book Not Recognized
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Oct 02, 2009
bob_computer
  • 3153 Answers
SOURCE: no writable WD smartware partition found
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
Hope this gives you the information you need
Bob
ExModerator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Posted on Dec 28, 2009
  • 146 Answers
SOURCE: I just had it from
restart the PC, do not plug the device. now insert the software disk in CD rom. Plug in the device. lower right tray, toy will see found new hardware. now doubble click on it and then start installing diver from the CD rom by clicking and pointing next inside the intall hardware pop up menu. after installation, it will ask for restart. do it and then it should work.
cheers!
Posted on Sep 08, 2010
I made a mistake installing my new WD 500 PATA drive. I need to remove the DDO because I can't see more than 131 Gigs of the drive. I'm using XP Pro and my MoBo bios will see the full 500 gigs....
If you have XP installed on this drive and it is functioning correctly it would be best to use a third party software to resize the C drive or create an additional partition with the free space that you are not seeing. Installing an application like Acronis Disk Director or Partition Magic will give you much more flexability on your storage space.
This is a freeware software link below for EASEUS Partition Manager.
http://www.partition-tool.com/
Jun 11, 2011 | Computers & Internet
Western digital wd10ears not detected in xp
If this is a second drive you will need to format it by going to Control Panel > System Tools > Computer Management. Select Storage > Disk Management. If you see your drive, format it and it should work.
If this is the drive you would like to use for your operating system you may have bad drivers. Western Digital has a how-to about this problem (url below). Essentially what you need to do is re-install the drivers for your controller card or motherboard. This requires finding the drivers from the manufacturer of that device.
(http://wdc.custhelp.com/app/answers/detail/a_id/1708/c/130/p/227,294)
May 10, 2011 | Western Digital WD Caviar Green WD10EARS...
Hello sir, i recovered some imported data from my corrupted hard disk (WD2500js) but after that i could not install the windows on it. I have partitioned it three times but didn't affect. i think i need a...
I think that your disk-drive is about to "die", and the symptom of not being able to install Windows (which tries to write many files onto the disk) is a strong indicator.
Is the drive still under warranty? If so, W.D. will give you a free replacement. If not, W.D. has a 'Customer Loyalty' program -- buy a new disk-drive from their web-site, and get a discount.
Oct 25, 2010 | Western Digital WD2500JS 250GB SATA2...
How can we install new software & game from pc to xperia
Download and install 'Astro File Manager' from the market for free.
Connect phone to pc and save the app or game you want to install to your SD card.
Disconnect phone from pc.
Go into Astro on the phone - you can now browse your SD card or phone.
Browse to the game or app and click on it.
Select 'Open App Manager' and you then have an option to install.
Once the app is installed, you can use the same procedure to un-install it.
NOTE - if you're downloading Android apps from the internet rather than the market, a lot of them are not actually compatible with the X10, but there are some really good ones out there.
Jun 15, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Formatted and installed a WD 60gb hd as slave and is not detected
Did you format this drive to NTFS or FAT32. It may not rcognise it as a slave drive on a format other than NTFS
Apr 11, 2010 | Western Digital Caviar WD600BB 60 GB Hard...
WD MyPassport capacity is shown 0 bytes in my computer
Did you get a install disk with it.Try installing it.I am sure you have tried it in another port on the computer.
Good luck
Sep 17, 2009 | Western Digital My Book Essential Edition...
I have new wd external hdd 250 gb, its not detecting on my desktop.
Is the drive formatted? Did you get an install disk supplied with it? If so try running it.
Check your system BIOS and see if the drive is being detected there. Also you can check the Device Manager in Windows to see if there any issues with the drive.
Sep 12, 2009 | Western Digital WD Passport 250GB Portable...
I am trying to install a new WD Scorpio Blue hard drive on my Compaq presario x1000. The computer is not recognizing the drive (it says none installed). When I insert the installation CD it gives me a disk...
I would first make sure that your laptop can actually handle the HDD's capacity, and the interface, then go into yout BIOS and make sure any switches that need to be hit are in fact set properly. First make sure that it is actually powering up. Regardless of what's going on, if the jumper settings are correct your motherboard should notify you that there is a proper conection in the bois display. If you don't see this, make sure that it is actually powering up, and that the jumper pin(s) are positioned correctly.
Jan 06, 2009 | Compaq Presario X1000 Notebook
Computer freezes
Actually sounds like the hard disk if faulty - as in Device Manager tries to install a device for it, but because the drive is malfuntioning, the driver craps itself, taking Windows down with it.
Have you tried it in another Computer ?
Nov 07, 2008 | Western Digital My Book Essential Edition...
Installing a secondary HDD
it needs to be activated . control panel/administrative tools/ computer management/disk management
May 29, 2008 | Western Digital Caviar WD2500BB 250 GB...
Western Digital 2TB My Book Studio II Hard Drive Logo
46 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
