Parts diagram whirlpool stylemaster 4213632
Water leak under tub
  • 530 Answers
SOURCE: My washer machine Whirlpool Ultimate
is it filling filling filling and not stopping. or will it fill and stop when it is supposed to. if it's fill fill filling could be a hole in the pressure hose or a faulty pressure switch. but if itt does all the cycles and is leaking you probably have a bad pump tip the unit back a little so you can see under but do not tip all the way you will see the pump. see if it leaking if so replace tha pump.
Posted on Jan 04, 2009
SOURCE: Water leaking from seals under tub; draining water on spin cycle.
Here is a website which might provide you with the internal diagrams and the facility to buy the necessary parts. Just enter the model number in the following displayed page and choose your model from the displayed search list.
click here for Appliance Parts Pros
Else will fetch you the direct link for the machine if you can provide me with the model number and the firm name.
All the best with the machine and in case of further doubts regarding my solution please do post your comments.Would be glad to help you out.Also please do rate my solution as the rating is very valuable.Thank you in advance.
Posted on Apr 10, 2009
philbran
  • 242 Answers
SOURCE: washing machine does not spin
If the unit is making noise while set to spin but not spinning replace the motor coupling for the fix.
If the unit is silent when set to spin replace the lid switch for the fix.
Both are very common and not expensive plus easy to find online with the model number under the lid. Let me know if you have any other questions.
Phil
Posted on Apr 11, 2009
  • 32 Answers
SOURCE: Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Posted on Apr 22, 2009
jmgldsmth
  • 2005 Answers
SOURCE: leaking tub on whirlpool washer
replace the main (under tub) seal
Posted on May 04, 2009
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Grinding noise in spin cycle
It sounds like the drain pump needs replacing, its bearings have failed or there is something from the wash jammed in it. But before you buy a new one, get the machine checked by an expert in case lots of parts are damaged.
Dec 20, 2013 | Whirlpool Washing Machines
Whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Feb 11, 2010 | Washing Machines
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Whirlpool Washing Machines
Water spills all over the floor
Replacing Parts Second, Replace Leaky Internal Hoses
If the supply hoses aren’t leaking, open the cabinet and inspect the internal components. Belt-drive machines typically have a rear access panel that unscrews. Access direct-drive machines by removing the two screws on the outside of the control panel and flipping up the lid. Then pry up the cabinet clips and pull off the entire cabinet. With the cabinet open, restart the fill cycle to check for internal leaks. Look for additional clues like rust and calcium deposits. Most often you’ll find the leaks in the spots we show inFigure A.
Hoses tend to leak around a worn-out spring clamp. First try to remove the spring clamp with an adjustable pliers. If you can’t get it, you’ll need a special $15 hose clamp pliers available from your local parts supplier. Replace the old spring clamp with a new worm-drive clamp. If the hose itself is cracked and leaking, remove it and take it to the appliance parts supplier for a replacement.
CAUTION: Unplug the machine before performing any repairs.
Buying Parts
Washing machine parts are available at appliance parts distributors. (Look in the Yellow Pages under “Appliance Parts.”) Try to find a parts supplier with a well-informed staff, ideally ex–repair technicians, who can provide diagrams and help diagnose any problems specific to your brand of machine. A great Internet source is www.searspartsdirect.com. Enter your model number to access exploded-view diagrams and a thorough parts list for easy on-line ordering.
You’ll need the brand and model number for proper part identification. Model numbers are usually stamped on a small metal plate located under the tub lid or on the side or back of the machine. Copy down all the plate information and take it along to the parts distributor.
Third, Replace a Leaky Pump
Fourth, Replace Worn-Out Tub Fittings
The most challenging repair is fixing a leaking tub fitting, whether it’s the air dome seal ($5), the center post gasket ($8) or the tub seals ($15 to $20). Before proceeding, make sure that telltale drips are coming from around the tub. The details of this repair vary by brand and model. The details we show are for most Whirlpool and Kenmore belt drives. Study a schematic drawing or consult a parts specialist if your machine is different from what we show.
You’ll need a special $15 spanner wrench to remove the tub and replace the tub fittings on this type of machine. It’s available at your local appliance parts supplier. You can open the top of many machines by releasing the spring catches. However, on others you have to unscrew several screws and lift off the entire cabinet. Look in your owner’s manual or at a parts diagram. (See the manufacturer’s Web site or one of the sites listed in “Buying Parts.”) You’ll have to unscrew the water inlet and the tub snubber before unclipping the ring. Fastening systems for these vary by brand, as do attachment methods for the agitator and inner tub.
There are four tub seals that secure the outer tub to the cabinet, each consisting of a bolt with a rubber and metal washer. Rust often develops around one of the tub seals, causing a tub leak. A new tub seal kit will come with four new bolts and oversized rubber and metal washers that will seal small leaks. But if the tub is completely rusted through around the bolt, it’s time to buy a new washing machine. Replace all four tub seals.
If the leaking occurs only when the machine is agitating, a bad center post gasket (“doughnut”) is the culprit. Remove the outer tub to replace the center post gasket. While you’re at it, replace the air dome seal as well. Reassemble the washing machine and run a test cycle.
Jul 14, 2009 | Whirlpool Washing Machines
Apr 22, 2009 | Whirlpool Washing Machines
Washing machine does not spin
Phil
Apr 11, 2009 | Whirlpool Washing Machines
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
